Samsung WF419AAW/XAA water in drum - Washing Machines
2 Suggested Answers
SOURCE: I have the Samsung washer
You should make sure that everything is screwed in tight. Just because you bought it new does not mean it did not come with out any basic defects. Fortunately the glass used on Washer doors is tempered and can withstand quite a beating without actually breaking. If you find that everything is screwed and sealed properly and the problem still persists make sure that the washer is level. If it sits on an uneven surface this can throw off the balance of the spin cycle and cause it to wobble off balance. If you have done that and it still persists its time to call the manufacturer and talk about a refund. As far as the scratched glass there are plenty of companies out there that can buff the scratches gone and clear again, here is a company to help you start your search scratched glass repair company.
Posted on Mar 03, 2011
Samsung electric dryer model dv520aep xaa 02 leaking water under drum (according to tech), is not drying, and when unplugged water leaks from electric cord! screen reads"replace thermostat". only 5 yrs....
you might need a repair man, or if you know how you can check things like make sure it has 220 volts you might need heat element or it has one of the sensors blown you need an electric tester to check them you can find videos on youtube
that will show you how. if you are able to sounds like your vent is clogged up that will make it blow the sensors in the back of the dryer, good luck!
Aug 15, 2017 | Samsung Dryers
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin ยท Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
I have a Samsung front loader washer wf419aaw/xaa. 2 days ago it started making a loud knocking sound during the spin cycle. The drum also feels loose. I have researched every site I can find but still...
it is best if you engage the services of a technician. While it could be bearings ( I doubt it ) it is most likely something between the wash drum and the outer case that is hitting during spinning. something like a ( from hosier)y wire, bobby pin, button, coin
Feb 12, 2015 | Samsung Washing Machines
I need to fix my front load washer
drums don't get loose, their bearings wear out. if it is old most likely it is toast, if newer then may be worth repair
Nov 21, 2014 | Samsung Main Board Washer Dc92-00301e...
I have a Samsung Washer Model # WF209ANW/XAA and when we start it water is pouring out where soap goes in and pouring out down the front and in the floor
Most likely there is a clog in the tube that connects the detergent tray to the drum.
Remove the top by removing 2 screws back left and back right. The top slides backward and off
Now remove the tube. You really cant miss it
Nov 20, 2014 | Washing Machines
Samsung Dryer Model DV419AEW /XAA Dryer will not
I doubt its the main board. Try seeing if the drum is tight and seeing if the belt broke by spinning it by hand. If the drum is real sloppy and you can't feel motor tension, you need a belt. I would rule out the mainboard until last because the belt is like 89 cents.
http://www.amazon.com/341241-Whirlpool-Kenmore-Dryer-Belt/dp/B00064NH6E
http://www.youtube.com/watch?v=zNATJ8qyqP4
Sep 27, 2013 | Samsung Clothes Dryer Control Panel Main...
I have the Samsung washer model WF419AAW/XAA. My problem is that when the washer spins occasionally the silver drum rim hits the glass on the door. That has resulted in a scratched glass door. I am afraid...
Mar 03, 2011 | Samsung Washing Machines
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
