Question about LG Computers & Internet
Lg gold star vga pin wire conect witch color
Vga wire prob
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: VGA Cable Wire Colors
I don't think and RGB cable will work with a VGA cable because the signal in the video card is completely different. It's not just the picture but the scaning and refresh rates are totally different. Even if you could wire one it probably won't produce a picture.
Posted on Jun 30, 2008
  • 14 Answers
SOURCE: Want to replace the vga
Posted on Oct 28, 2009
rockmeister
  • 2047 Answers
SOURCE: i am trying to find the color and pin code chart
Usually color coding on these cables are always different depenging on the country of origin as there is no universal color system. Although the pins also are usually not numbered in a uniform way so describing them to you might be quite confusing. Usually the best solution is to just get a replacement cable for your unit.Trying to fix the cable the way you intend to could cause damage to components in the monitor if not properly fixed and this would be more expensive that the cable. VGA cables usually cost less than $5.
Hope this olution has been helpful?
Posted on Apr 20, 2011
ErusTownsend
  • 592 Answers
SOURCE: VGA Cable disconnect form the
here is the basic vga pinout
Posted on Jun 29, 2011
How to repair power supply
It's probably the 'invertor', not the backlight or powersupply. That is assuming that the power-led does turn on ?
Jun 29, 2014 | Dell Entry E2311h 23 Led Lcd Monitor -...
Red cable crt
Sometimes certain pins are missed or added more.
Or some pin connection are bad.
Try this.
Use VGA to DVI adapter from laptop and see what happes.
Jun 21, 2013 | HP L1910 19 inch LCD Monitor
Want to connect 40 pin LCD ribbon cable to the 15 pin D type VGA
VGA pinout?
Not a prob,
http://pinouts.ru/Video/VGA15_pinout.shtml
Pinout of that 40 wire LCD ribbon cable in your hand?
Dunno
Each manufacturer is different.
IF, you find the pinout of JUST THAT LCD cable you have, LET ME KNOW.
Post back in a Comment, or click on Reply at the end of this solution.
Regards,
joecoolvette
May 12, 2013 | Computers & Internet
Color wiring code
what radio?1 shield 2 audio 3 TX 4 RX
Apr 05, 2013 | Cobra HG-M73 Standard 4-pin Microphone
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
May 22, 2008 | Car Audio & Video
13pins "from the inside monitor" "to the VGA 15 pins connector
hai dear,
i checked your problem and found that you open the cover of monitor and you find the two jack of data cable in main pcb and neck card( 2 connector of data cable).plz you cut the connector of data cable and you will find 8 wires in connector.related red(invild extra ground),green(invild extra ground),blue(invild extra ground),black gnd,white,orange,gold(extra gnd) and now you cut the red wire, you will find two wires.so you refix the main red wire pin no-1 of connector and red gnd pin no-6,green main wire pin no-2 and green gnd pin no-7,main blue wire pin no-3 and blue gnd pin no-8.check for the horizental sync and vertical sync wire you should go in main pcb which invild the other connector. there is present in print, h- sync(two wire of h- sync main wire in pin no-13 and other pin no-5) and ver.-sync wire in pin no-14.first you will check the whose h-sync and vert-sync in color and now finally other wires will fix any pin of connector.
Apr 03, 2008 | SAMTRON 55V 15" CRT Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
100 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
