Question about Sony PFM-42X1 Plasma TV
Hd outputs or connectins
I am unable to find the hd output to connect the DVD hd to the monitor.
  • 320 Answers
The only HD input on that monitor that is true HD is the 15 pin VGA input connector. It can be set in the TV menu to be used as an RGB input OR a color difference component input (Y, RY, BY). You will need a 15 pin connector that breaks out into 3 sperate cables; the ones I've seen break out into 3 BNC connectors and then you have to use dapators to convert them to standard RCA pulgs for connection to most consumer devices.
Posted on Oct 27, 2008
How to connect Sony dvd player to onkyo TX-8511 receiver
The TX-8511 is an older AV receiver with only composite video inputs. Your DVD player may not provide this type of output as it's not capable of HD video. If your dvd player has a composite output with a Red, White & Yellow set of outputs, that will connect into the Video 2 inputs on the receiver. Your TV will need to connect up to the Video2 or Monitor output. You'll need a set of composite video cables with the red-white & yellow RCA type plugs.
Here is a link to the manual for this receiver:
Receivers Receiver Stereo Receiver AVR TX 8511 Onkyo USA
Mar 13, 2015 | Onkyo TX-8511 Receiver
We do not know how to get input for a dvd player
check the back side of the monitor, or on the side of the monitor you will find the RCA connection through this side. the input of the video player comes in three colors, yellow for video output, red and white for audio output. just put the connector on its color allocation properly
Jul 22, 2011 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
How to fix lag on plasma to play ps2 guitar hero
Try to configure the following settings.
Go Video Setting, BD/DVD Cinema Conversion (Automatic), then BD/DVD Upscaler (Normal), then BD/DVD Video Output Format (RGB if you are using your PC Monitor, Y PbCb PrCr if you are on HD TV), then BD 1080p 24Hz Output (Automatic), then BD/DVD Dynamic Range Control (Off), then BD/DVD Audio Output Format (Linear PCM), then BD/DVD Audio Output Format [Optical Digital] (Bitstream). Go out of Video Setting and go to Display Setting. RGB Full Range (Limited), Y PbCb PrCr Super-white (On).
Hope this will help you.
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
Movies fade in and out
Configure the following settings.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
Are acer monitors unable to pick up HD video inputs?
There are two types cable to connect to LCD Monitor. VGA and the other is DVI,ight need DVI cable it has flat pins and is larger than the VGA small round pin models.
Dec 21, 2009 | Acer X193W LCD Monitor
Problems with Toshiba DVD Player
According to this Toshiba document a new soud driver installation will help you to solve this HD-DVD issue.
Check this;
HD DVD title doesn't play ("Unable to output the video to an external device")
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1664788xml&sliceId=&dialogID=24590306&stateId=1%200%2024588233
Jul 14, 2009 | Toshiba Satellite U305-S2812 Notebook
Cant get sound from speakers
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Feb 03, 2008 | Audio Players & Recorders
Hp hd dvd player for desktop wont play hd dvds
I had this problem. Turned out that I was using a DVI cable to connect my monitor to the video card, but my monitor was not HDCP compliant. Most HD-DVD's require the monitor to be HDCP compliant for digital output (i.e. over DVI or HDMI connections). Alternately, you can connect to your monitor via its analog (VGA) input instead, but you won't get HD output. I was able to do this using a VGA cable along with the VGA-DVI adapter for the video card output.
Cyberlink has a tool you can run to see if your system is capable of HD-DVD output. http://www.cyberlink.com/multi/support/bdhd_support/diagnosis.jsp
When I ran it, it gave me a red flag telling me my monitor was not HDCP compliant
Aug 05, 2007 | Pioneer VSX-D511 Receiver
Sony PFM-42X1 Plasma TV Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
