Question about Sony KP-57XBR10 57" Rear Projection Television
57" 2003 sony non-xbr projextion
My 57" sony has a bout 20-25 thin red lines in the shape of an hourglass (half circle down, half circle up) that become ver apparent when the screen fades to black/ darker scenes. I have turned up the brightness quite a bit to compensate but now all i have is terrible contrast!! Any advice is appreciated. Kind regards, Blake
  • vcares Jan 20, 2008
    We have the same problem and live in a town where there are no television repair persons. So we just gave up and bought a 50" Samsung Plasma at best buy. Sure is nice watching a tv with no lines in screen. We bought this television new in Spring 2004 for $2500.00. Very disappointed with Sony will stay away from their products.
There's a lot of talk in the internet that the pots in the front of the tv will take these (horizontal?) lines out . i have the kp-57hw40, and there is a web site with pictures on making the adjustment. i believe the bottom 3 pots are blue, green, red going from left to right. mark the pots first so you know where you started, and they say it takes just a hair adjustment counter clockwise to remove the lines. Only go to the point the lines disappear. web site shows how to get front cover off via two screws hidden in bottom and then take off the cardboard cover to get at pots. Not to be smart, but don't be careless, keep hands out since there are high voltage circuits just inside there. . . .
Posted on Dec 18, 2007
I had the same with my tv and i removed the front speaker grill and the carboard cover. there are 6 screws. the ones that need adjusting are on the bottom. turn them very slightly until they go away.
Posted on Jun 28, 2008
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
Sony tv problems
xbr 65x 850b sony ultra 4k tv smart ... what cause it to be black screen but you can hear the show playing
Jan 10, 2014 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia xbr has red vertical lines going through it
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 31, 2012 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
My TV has been acting strange lately. When I turn it on, the screen looks purple and has these horizontal lines up and down the entire screen. They don't expand to both sides of the screen, though. WHen...
there seems to be a problem in the horizontal circuit...there is a control on the flyback transformer that is labeled "screen". (you'll have to take the back off) The flyback is the component that looks sort of round with the red high voltage lead coming out the top and connecting to the top of the picture tube.On the back of the flyback there will be 2 or 3 controls if 2 there will be 1 focus and 1 screen, if 3 there are 2 focus and 1 screen..using an insulated flat blade screwdriver, slowly turn the screen control counterclockwise to see if this will make the lines go away...if not then there is a horizontal cicuit fault and quit possibly a pincushion problem(hourglass effect)..these will need to be checked by a service shop
Jan 22, 2011 | Sylvania 6432TFY TV
I have a vertical line in the middle of my screen
Call for warenty repair,ur tuner board have problems.Or tries bring it back at were the store u buy it at.Return it exchange for another one.
Mar 23, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony Bravia 46Z4100 has a thin vertical red line on the screen
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
May 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I get a thin line of distortion on my sony xbr 42in
Your format is wrong. Make sure that your tv is in full mode and your direct tv is in 1080i stretch mode. This should correct the problem. Also, WB is having problems. This is common on their channel. If it is happening on any other channel, try the above. Hope this helps. JOHN
Feb 27, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
May 30, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony KP-57XBR10 57" Rear Projection Television Logo
231 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
