Question about Magic Chef Refrigerators
How to install the defrost timer magic chef model mcbr1010w
4 Suggested Answers
aasc
  • 1606 Answers
SOURCE: Defrost timer might not be working
The timer is located behind the fridge , down by the compressor .
Posted on Aug 23, 2009
  • 39 Answers
twist your defrost timer with a screwdriver clocwise till it will click and compressor shut off, check voltage on defrost heater. You should have 120volts.When wait 20 min if compressor start up back and defrost heater is off ...your timer is fine. It can come on early then 20 min....
P.S. defrost heater located on the bottom of the coil, also make sure your defrost thermostat is frozen when you going to check voltage on your heater. Thermostat located on the top of your coil.
imufo2
  • 3773 Answers
SOURCE: magic chef model mcbr1010w - freezer works fine.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 28, 2011
Where is the defrost timer on a Magic Chef Model RB23GA-3A top freezer Refridgerator?
It is located in the mechanical space of the unit. Please review the picture.
Feb 23, 2015 | Magic Chef Refrigerators
4.0 magic chef freezing on the back wall
you have a defrost component not working , timer , thermost , or defrost thermo
Nov 29, 2013 | Magic Chef Refrigerators
Have a magic chef refrig model mcbr1010w it is not cooling i have not heard it running there is electric to the appliance light is on inside but nothing else is running
in the bottom back of the fridge, there is a black box (3"x3") with a little white plastic screw type thing in the center. turn it slightly to see if the fridge starts up. Mine is doing the same thing, making it untrustworthy as it shuts off at will. I am currently looking for the replacement part.
Oct 21, 2010 | Magic Chef Refrigerators
Magic Chef Side by side...freezer side frosting and Refrigerator side not cooling
Your defrost timer,defrost thermostat and defrost heater need to be checked.
The heater and thermostat are inside the freezer behind the back freezer panel.
The timer is underneath the refrigerator either the left front or right rear.
Jun 25, 2010 | Magic Chef (CSD2610KRW) Top Freezer...
Aug 23, 2009 | Refrigerators
Aug 23, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic chief frig mcbr1010w defrost timer help squence of operatio
The solution to all of the above problems. Disconnect the blue wire from the timer and connect a wire from the white neutral to #1 pin on the timer. As shown the timer operates thru the defrost bimetal
Jul 31, 2009 | Magic Chef CTB1821AR Top Freezer...
Where is the defrost timer on a magic chef refrigerator
The defrost timer for your model is located in the fresh food compartment. Providing the model number above your post is correct. The part number for your defrost timer is 61005388
You can visit my sites if you like and enter part or model number to get the models or parts you need. If you need help or need answers let me know.
Thanks, Sea Breeze
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Jul 09, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerators Logo
32 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
