Question about Janome MyLock 634D Mechanical Sewing Machine
How to serge lycra fabric
How to sew lycra fabrics on my serger.What settings do i need ? I would also like to know how to make a coverstitch on my serger?
fixitruss
  • 6 Answers
SOURCE: Machine not sewing
 If you have the machine threaded correctly, and are absolutely sure. New needles installed and it still does not sew, you most definitely have a timing problem. You should take to a qualified service center to be properly timed.
Posted on Oct 10, 2007
bargainbox
  • 1388 Answers
SOURCE: janome 9000
Remove the needleplate and clean out the lint from between the teeth of the feeddogs........it is the most likely reason, the lint holds the feeddogs below where they need to engage fabric.
Check your Presser foot tension is at 3 then do a test.
If this is not sufficient the method of adjusting feeddogs is possible at home, tho perhaps not for those lacking some confidence in mechanical adjustment.......so post back for detail if needed.
Posted on Jul 31, 2008
  • 297 Answers
SOURCE: My Janome JD1818 will sew in reverse but not forward.
Switch broken, have it replaced
Posted on May 06, 2009
SOURCE: MyLock 634D won't serge
Check that your lower looper is actually threaded and not tangled with the upper looper (needle thread) when it moves. I wish they'd include pictures in the manual how to lay the thread.
Posted on May 18, 2009
  • 161 Answers
SOURCE: Janome MyLock 634D serger won't
if the handwheel won't turn, i'd double check nothing is still stuck. also, make sure you didn't half disengage the blade as they have several positions ( so you can disengage it for rolled hem etc) If you can't find anything I'm sorry to say something may have been damaged when the fabric got caught.
Posted on Sep 14, 2010
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
I have an Elna Junior Club sewing machine and I am sewing Lycra and using the number 14 stretch stich. It just loops and bunches up underneath even though I have set everything as instructed.
Did you pre-wash the fabric? Sometimes the finish applied at the factory causes problems. Also, be sure to use a ball point needle on knit fabric. Sometimes, using a walking foot, teflon foot, or roller foot will help the fabric move smoother through the machine. It could be that your machine is experiencing a problem with the back-n-forth movement of the stretch stitch. Otherwise, here are more guidelines to review:
30 Best Tips for Sewing Knits with Serger Sewing Machine Serger Pepper
Sewing Spandex Tips
Feb 02, 2017 | Elna Sewing Machines
How do I set my Bernette 334D to overlock thin T-shirt material?
Thin, light-weight fabrics present some issues with sergers, ie the fabric tunnels with the stitching. Usually, it is better to use a narrow seam. Also, a stabilizer (wash-away) or even adding a strip of thin paper (toilet tissue, adding machine tape, etc) to the seam will help the fabric hold its shape when stitching. I have also sprayed & ironed heavy starch on thin fabrics to help stabilize.
sewing patternreview com
Serging Chiffon and Other Slippery Fabrics
Make It Handmade Understanding Your Serger Features
Jul 02, 2016 | Sewing Machines
Does anyone have a suggestion? I have threaded the machine correctly but I cannot get the machine to sew.
You have a nice serger, so let's start with some basics:
Is your serger cleaned?
Go back to the instruction book and set the entire machine to the factory settings. For example, set all the dials to tension 4. Use quality thread which is made for your spool holder. Usually cones of thread work best. Use an appropriate fabric, not sheer, not very heavy drapery fabric. Make absolutely sure it's threaded properly. Finally, make sure all the threads are under the presser foot.....then start serging. If the serger still won't serge without tangling, it might be good to have it serviced. I find that buying a new serger is more useful than having a worn out one serviced. Good luck!
May 05, 2014 | Brother 925D Serger
Upper looper hits lower looper
The upper/lower looper need realignment, requires a qualified technician to do this.
Oct 21, 2013 | Brother 1034D Serger Sewing Machine
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
The looper stitches are coming over the cut edge of the fabric. I have the cutting width set to WIDE.
you don't say what make and model serger this is.
However, as a rule of thumb, set the blade to widest setting, then test serge and tighten up the top and bottom looper threads to encase the cut edge neatly. So you would need to turn the dials on the two right hand knobs to a higher number, just move each dial one number at a time and test serge again.
The other possibility is that the thread is not between the tension discs properly, so check your thread paths, when you pull on the thread below the tension dial, it should feel firm to pull.
I always test serge scraps when sewing a new fabric and adjust the tensions to suit it before beginning a new project as a lightweight fabric will behave differently to a heavy fabric.
Apr 02, 2011 | Sewing Machines
Janome MyLock 634D Mechanical Sewing Machine Logo
59 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
