Townhouse ac/heater combo won't start
On Saturday I installed a new thermostat. According to the thermostat hotline I must have touched the blue (c) and red (rh) wires together and blown the transformer fuse. I went down to the bryant payne 517E fan-coil and fan unit, opened it up and uncovered the motor (below) and wiring on top. looked inside for a (car) fuse looking thing to no avail. What does the fuse look like? Supposedly it should be easy to replace.
I am not familiar with this air handler, but I haven't found too many with fuses. You just blow the transformer... but if you found a place that says there is a fuse, maybe there is.
If you can use a volt meter, check the voltage between the red and blue wire in the thermostat. It should be 24 volts AC. If it is there, your problem is something else... Some might suggest you use a short jumper wire from the red to the green and see if the fan comes on to check your 24 volts if you don't have a meter, but I would never suggest that...
If you determine that the 24 volts is not there then you should find that transformer in the air handler and follow the leads out and see if they lead to the fuse, if it exists. You might consider that the transformer is bad if you can't find a fuse. If able, check the primary for your supply voltage, 115 or 230 volts AC, and the secondary, 24 volts AC.
If your lucky, someone that is familiar with this model will answer with all the locations, etc...
Always be careful when working with electricity. If you decide to get into the air handler to troubleshoot your transformer, turn off the breaker while exploring and only turn it back on when you are ready to make voltage measurements and are confident that you know what you are doing.
Posted on Jul 17, 2017
ACTECH
  • 80 Answers
SOURCE: Rheem furnaace blower stays on
wiring is ok but should have a yellow wire to y this for your compressor and blue should go to b
Posted on Dec 19, 2007
chillmaster
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
pierre1811
  • 144 Answers
SOURCE: I have Bryant HRV and the motor has failed.
Wire nut and tape the blue and red wires they are not used.
Posted on Mar 06, 2009
farfield
  • 462 Answers
SOURCE: CARRIER AIR CONDITIONER/HEAT PUMP PROBLEM WOULD
what I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side.
A quick way if the primary side is burningout due to a problem with the low volt side:
1 MArk all the thermostat wires at the indoor unit
2 Disconnect them at the indoor unit.
3 Check main line voltage before proceeding (A 208 volt is not considered 220V and 240v Is not considered 208V> In these circumstances the voltage may have changed with the power company replacing a transformer and now you need to change the main power input lines at your control transformer for the correct operating voltage). If okj then proceed:
4 If you have an amp meter attach it to one of the lines going to the transformer.
5 Apply main power and listen for hum, note if smell starts again and if so problem has to be in board or main incoming voltage too high or too low. Amp draw should be less than 3 amps.
6 If your to this point and still havent found any trouble in the above as of yet, Connect the wire marked "C" together. Then just touch the thermostat wires one at a time to the places where they go on the indoor unit and watch the amp meter. If you donmt see the meter jump the circut is probably ok but leave them disconnected until you touch all of them to the correct place or wire. Here is a possible problem I ahve seen a thermostat wireing problem if the wires are stripped too far and a "whisker" of the wire sticks out and allowes one of the other wires to cross short out. In this case just cut off the excess wire or bend it over out of the way asnd continue with the test. You can always cut it off later after the tests. If you see the meter jump up and stay up and /or blowes the fuse the wire that you used and it blew is where to consentrate.
7 No wiring problem found means that you could have a relay or contactor not pulling in properly.
and this will cause the amp draw to go way over the transformers power out put or VA rating.
8 Inspect the thermostat wiring for the "whisker" I mentioned above.
9 If you have done this to the end of the thermostat wires and your main incomming voltage is correctly wired in on the transformer andf your relays and contactors are pulling in evenly and not delaying excessively your problem should be fixed.
If this helps you please rate me as high as you can and thank you for using fixya.
Posted on Apr 25, 2009
  • 73 Answers
SOURCE: AC unit fan won't turn
Yes those are the Thermostat Wires to the Unit Reconnect and you should be Fine.
Thanks
Please Rate me
George
Posted on Apr 28, 2009
Which thermostat to use 4-wire Goodman gas furnace
blue is common. never let that wire touch any other color or you will short the transformer. Use a thermostat for single stage gas heat. R=Red W=White Y=Yellow which should go to the outdoor ac contactor and C=Blue which should also go to the outdoor ac contactor. If in doubt call a qualified Heating contractor to help you install. It can get quite expensive letting the smoke out of your parts.
Aug 21, 2014 | Heating & Cooling
I installed the RTH 230B thermostat, Theheat only works when set to the cool mode, I only have gas furnace(no ac unit). My old wires are Red, white, green and blue. What wires go where?
Hey jim Try....RH/RC jumper (connected with a small piece of wire)...RH/RC=RED...W=WHITE...G=GREEN blue=unused... should give heat only (in heat mode) no ac..tks
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
I put a new thermistat o a/c heat but only the fan is turning on the colors where white yellow red blue I did not put the blue on the O/b screw
your thermostat may need to be programmed according to the heating system you have. that'll be in the installer instructions. For the wiring, open up your heater to see a circuit board. coming to it are the thermostat wires, match your thermostat accordingly.
Normally the installer would do red - R, White - W, Yellow - G, and Blue - C.
It varies, so to be sure, check the furnace.
May 06, 2011 | Heating & Cooling
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Having a problem with my AC/Furnace. AC was working fine and was turned on for about 3 weeks. Thursday night it cooled off and we opened up until Saturday morning. On Saturday morning the AC would not turn...
I think your problem is poor usage of the device,i.e. overloading the system. try running better cables to your furnace and ac. The reason i am lead to believe that is. If you already hired a pro to come and fix it for you,and he/she could'nt then what else could it be? in my experience ac units use electricity like microwave ovens.and power tools
Sep 12, 2009 | Heating & Cooling
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
The AC or Heat will not turn off once set temp is reached.
The yellow and the blue wire are commonly interchanged. as long as it is hooked up the same at the gas heater. It sounds like you did it right.
Jun 02, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
