Question about Altec Lansing VS2120 2-PC SPEAKER SYSTEM (Black/Silver) Computer Speakers
Altec Lansing VS2120 2-PC SPEAKER SYSTEM crackling and popping
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
ginko
  • 19396 Answers
SOURCE: driver/installer
Here is the 221 download page: http://www.altec-lansing.com/product_details_intl.asp?country_code=pk&region=northam&pID=221
cheers
Posted on Feb 16, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
SOURCE: Altec Lansing ada745
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
How do Altec Lansing AVS200W 2-Piece Multimedia Speaker System connect to your computer
Using a regular audio cable with 3.5 mm. connectors at both ends, connect your computer to the speaker from the the headphone jack to the 3.5 mm LINE IN jack on the speaker.
Jul 10, 2014 | Altec Lansing Avs200w 2-piece Multimedia...
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ADA995 Speaker system partial speaker play
Drivers and support softwares for Dell Dimension 9100 are still very much available to Dell's website (here). Download the audio driver for your StaCruz Audio card.
Hope this helps. Please don't forget to rate.
Nov 07, 2009 | Altec Lansing ADA995 Speaker
Connect Altec Lansing ADA745 to HD TV RCA output for home theater
It won't work like this due to this being a computer only speaker system. It requires the drivers to work with a computer & a Home theater does not recognize the format. Sorry.
Feb 25, 2009 | Altec Lansing Multimedia Computer Speakers
Connector problem
just buy a minijack-minijack cable. It's very cheap.
Jun 05, 2008 | Altec Lansing VS4121 Speaker
Output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Dec 24, 2007 | Audio Players & Recorders
Altec Lansing VS2120 2-PC SPEAKER SYSTEM (Black/Silver) Computer Speakers Logo
26 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
