Question about Garden
Removing cuttingblade masport quantum xts 50
How to access cuttung blade
5 Suggested Answers
  • 1116 Answers
SOURCE: how to remove the blade from the Masport lawn
There is a nut in the center of the blades. The easiest way to remove this nut is with an impact wrench. If you don't have one there is usually a hole in the disc where you can insert a screw driver to lock the blade from from turning and you will need a long handle ratchet in order to give enough torque to remove the nut. Once the nut is removed, the blade will slide right off. If you are doing this to sharpen the blades, you do not need to remove the blade to do this. Use a 1/2 HP grinder wheel and just evenly slide the wheel down the blade until it is sharp. CAUTION: it will cut you finger. Make sure you disconnect the power and the fuel is turned off at the time you do any of this work....
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 09, 2011
SOURCE: replacing starter cord,best way? for
I have just completed the same process and solved the problem. Firstly, have you joined this site because I did (free of charge) and found a video showing me exactly what to do. Let me know if you dont find it and I will tell you what is required.Regards Gary.
Posted on Oct 24, 2011
  • 3 Answers
SOURCE: what sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Briggs and Stratton are usually 4 stroke engines.
However, check to see if there are THREE receptacles for petrol/oil. Some 2 strokes have a seperate tank for 2 stroke oil so there will be three receptacles on these engines - one for petrol, one for 2 stroke oil and one for gearbox oil.
Other two strokes are like 4 stroke engines insomuch as they have only two receptacles - one for fuel and one for gearbox oil. The difference with this type of 2 stroke is that you have to mix 2 stroke oil with the petrol ( usually 1 part oil to 50 parts petrol ) before putting it in the fuel tank. This is called "premix".
Posted on Oct 30, 2011
SOURCE: Quantum XTS 50 keeps stalling,
Try first as it is easy and 50% of the time is the problem Clean the small hole in the side of the hollow bolt that holds carb bowl on, located on the bottom of carb bowl with some carb cleaner if you have or just blow it out,
Posted on Dec 03, 2011
Replacement cuttingblade for gardenline lawn mower RG-PM 48 S B&S
Fixya does not sell replacement gardenline cutting blades.
Jan 18, 2018 | Garden
What is the mix ratio for Masport quantum xts 60
gas to oil mixture (in my books ) is 5 to 1. 5 gallons of gas to one litre of oil.
Oct 19, 2014 | Garden
My quantum xts 50 after priming wont fire
does it start when you prime it or does it not start at all? if you prime it and it runs until the prime burns off then won't start again, try priming it again. If it starts and runs until the prime burns off again then it is a carburetor issue. It isn't supplying the engine with fuel to run after the prime is gone
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 20, 2013 | Garden
Quantum xts 50 timing
Check the air gap between the coil and flywheel. Also the solid state trigger in the flywheel may be faulty.
Dec 12, 2012 | Garden
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 | Garden
Replacing starter cord,best way? for Masport Quantum XTS 60 push mower
Sep 14, 2011 | Garden
Quantum XTS 50 keeps stalling, and needs to be primed again every time to start.
Jan 30, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Blades on Masport Ride-on won't disengage.
Yes sir assuming that all parts are origional. 9 times out of 10 its a rusted up idler arm. Remove the rust and grease up the idler arm bushings. Lubricate all other pivot points with machine oil or wd40.
Nov 21, 2009 | Garden
Garden Logo
224 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
