Question about Maytag Washing Machines
How do you remove a maytag lat2500aae series lid switch
4 Suggested Answers
Joe Onley
  • 363 Answers
SOURCE: remove lid switch, which does not work
Found this online, should be what you need, Good luck,
Joe
http://forum.appliancepartspros.com/dishwasher-repair/8110-replacing-lid-switch-whirlpool-kirkland-washer.html
Posted on Aug 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: I have a Maytag LAT2500AAE top load washer. The
check the balance ring on the tub just below the tub cover and tub cover gasket which can be done from the top of the machine by removing the top cover,while doing this pull and push tub from side to side and see if it moves easier in certain directions, if it does you may have a tub spring broken on the tub leading to an un balance condition cause the springs stabilize the tub like a shock absorber on an auto, if this is it then you need to access the lower unit area by removing the front cover of the unit there are screws at the toe kick panel to remove this panel
Posted on Dec 08, 2009
mc1bean
  • 3053 Answers
SOURCE: I have a Maytag Atlantis MAV7700AWW washer. Lid Switch suspected.
Hello, sue
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Nov 01, 2011
Can a lid switch on a maytag bravos quiet series 400 model MVWB800VU0 be bypassed for testing, lid switch passes continuity tests but machine won't finish a agitate cycle?
the switch can still be bad manually even though it shows good electronically. How ever if its bad you seldom get some agitation then goes off unless ur opening and closing it? once its bad u get nothing, hence ur problem may be elsewhere. but Im u pics on how to jumper it, I myself think ur problem is in the timer perhaps sticking? if u have no agitation then check the water pressure switch and the door switch
Jun 22, 2015 | Maytag Washing Machines
My Maytag performa series LAT2500AAE fills to the medium level no matter which setting I use. It does NOT overflow.
If your infinite water level switch has a reset, perform this before changing the water level setting prior to your next load, this is usually done by rotating the knob to the reset zone, then back to your desired water level setting. If your problem still exists, you will most likely need the water level switch replaced Part# 22001776. Pleazer Appliance...
Apr 16, 2014 | Maytag Washing Machines
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
Dec 08, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag washer stops at spin cycle
Hi, You can get to the lid switch by removing the screws that hold the control panel to the cabinet. This model has a fuse included with the lid switch.
I hope this helps you.
Please let me knwo if I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
The drain hose on a Maytag model #LAT2500AAE is leaking so I would like to replace it. From the back panel, it is way inside and difficult to reach. How do I remove the front panel?
there are 2 clips at the bottom left and right that pushes in or you may have the one with 2 screws on bottom left and right cornier..
Jun 03, 2008 | Maytag Washing Machines
I have Maytag LAT2500AAE. I took off the front cover and I see water leaking from the tub bearing during the rinse cycle. I think I need the Tub Bearing Repair Kit PS60151. Is this a difficult...
Tub bearing replacement on ANY Maytag can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Maytag washers require specialized tools for removing certain components of the machine.
May 29, 2008 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
