Question about Kenmore Refrigerators
I have a kenmore refrigerator model 795.77249601 on the door information it says er ff what does that mean
  • 72 Answers
SOURCE: What does message: Er FF mean?
That means the freezer fan is blocked, you need to order a new High voltage board, the ice has built up enough from not defrosting that it is interfering with the operation of the evaporator fan.
Posted on Jun 22, 2009
SOURCE: I have a Kenmore Elite Trio Refrigerator. The
I have the same problem what is the solution
Posted on Dec 22, 2009
SOURCE: kenmore elite french doors bottom freezer Model #
Well you got a kenmore that i believe is actually made by either Samsung, or LG, since Kenmore does not make any refrigerators, they are ALL taken from other name brands with the name kenmore put on the front. I would start by looking at your owners manual for troublshooting codes, but chances are you have a faulty evaporator fan motor, either the motor itsself is out of balance, or possibly ice is obstructing fan blade, and you'll need to find the source of that problem instead. hope this helps
www.FixMyFridge.net
Posted on Mar 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: er-ff error message on Kenmore Trio 795
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
What er ff mean at Error message on display of Kenmore Elite Bottom Freezer Refrigerator
Hi.
Error ff (er ff) means defective fan detected. Before calling support or before replacing the fan try performing a complete defrost by leaving power disconnected for one day (remove food from inside the unit first). That will fix the problem if the fan was temporarily malfunctioning because of ice formation. If that does not work the fan must be tested before replacement.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The display is showing ER FF WHAT DOES THAT MEAN
error fresh food means refrigerator probably bad thermistor in refrigerator ( ff refrigerator ) fz freezer
Jan 27, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore Elite ER FF
Possible sesor error. Unplug for bout 10 min then plug back up.
Jan 30, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Error message
FF means the board hasn't recieved a response from the freezer fan.  Check voltage to fan.  If voltage is there then replace the fan.  The fan is most likely the problem.
Nov 01, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
