Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door opens and shuts on its own
I notice one safety sensor stays on and the outher works fine however the door goes up and down on its own please help thanks jonney
I had the same problem with my Craftsman opener and found that I had pierced the cable leading to one of the eyes and was shorting out on both negative and positive wires. Something to look for. I went out and put up a brand new genie screw drive and that is when I found out about the pierced wire. also make sure the eyes are perfectly in line. Hope this helps. Cheers.
Posted on Oct 30, 2008
Back door to my house wont close securely...wind blows door opens its that easy to open it -
adjust the door striker plate in the door frame so that the lock tongue goes into it
Jan 17, 2015 | Building Materials
Garage door spring ,how can I change the spring
Garage door springs and their repair are one of the most dangerous jobs a Person can undertake in a Home.I strongly urge you consult a Professional.There are many aspects that must be taken into consideration and lack at any of steps can lead not only damage but maybe death.I\'m cheap as Hades,have assisted repairs on a garage door-advise keep away from springs.
Jul 13, 2014 | Building Materials
How do i reprogram garage opener model 139.53776
To ensure that old codes do not work, first press and hold the SR code button (Learn) on the garage door opener's control panel. Hold the button until the LED goes out. The Learn button is a colored button that is usually on the back panel to the left of the force and up/down adjustment knobs. Sometimes the control panel is on the side of the unit.
Next get a helper to make the programming easier. One person will need to press and release the Learn button. Then within 30 seconds, the second person (or a fast moving individual) needs to type in a 4 digit code and press the enter key on the key pad. The LED near the learn button will flash when the code is received.
If you reset all of the codes, you'll need to repeat the fast press and release of the Learn button. Then press a control button on the remote for most of your other door opener remotes. (There may be a pair of remotes that came with the garage door opener that will never be forgotten.)
I hope this helps.
(This works for all of the Craftsman door openers that I've dealt with.)
Jul 10, 2014 | Building Materials
I've got water coming in through the bottom of my door at work. It's coming in a steady stream through a crack in the marble. Can someone please give me a pointer or two?
If you have water pipes/ heating pipes in the concrete floor then from the crack I would suggest that the floor movement has broken a pipe allowing the water to flow out the crack under the door. To test this turn the water off at the mains and if the water stops flowing after a short period of time then that will indicate the fault. Allow enough time for the water in the pipes up to taps to drain back out
Jul 01, 2014 | Building Materials
I want to set a new password for them, i was lose old password, let see the video.
Do not understand what you want ? If you have a device not working or you need information on that device. respond with a make and model
May 28, 2014 | Building Materials
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
96 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
