Question about Everex StepNote NC1500 Notebook
Battery died need operating system it was deleted when battery died
  • 1 more comment
  • Patrick R. Feb 22, 2012
    what's
    Sorry about that, what's your preference?Ā  Linux, windows98, XP, Vista, 7?
  • browneyesdre
    browneyesdre Feb 23, 2012
    Vista
Deleting old email addresses on a Mac
There are two places to do that:
1. in the system address book (found in Applications/Contacts
2. in the address book of your email program. I use Thunderbird and Thunderbird has its own address book
Sep 18, 2014 | Apple Mac OS X 10.4 Tiger for Mac
It was 100% battery full and when i turned it on to used it died suddenly
Your battery storage capacity seems to have died out. You can check by charging it again while your PC is on and then by disconnecting the power adapter. If it dies again, then you may need to purchase replacement batteries.
Please feel free to contact us in case of any query.
Regards.
Dec 13, 2010 | Computers & Internet
TI-nspire screen doesn't work
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
My calc wont turn on at all no matter what i do.
Try these, courtesy of the TI Knowledge Base
Jul 23, 2009 | Texas Instruments TI-Nspire Graphic...
My TI-nspire CAS doesn't want to go on! I changed batteries! Tried the contrast buttons! Nothing works
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
Jun 10, 2009 | Texas Instruments TI-Nspire Graphic...
Here is what the TI knowledge base says about a calculator failing to turn on.
Mar 08, 2009 | Texas Instruments TI-Nspire Graphic...
Calculator keeps powering off after a few seconds
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Hold down [Home] [Enter] [P], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
    1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
    Note: TI-Nspire family model options 2 and 4 above require that the OS be reinstalled. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Dec 03, 2008 | Texas Instruments TI-Nspire Graphic...
Won't boot into new screen
Nov 22, 2008 | Texas Instruments TI-Nspire Graphic...
Everex StepNote NC1500 Notebook Logo
105 people viewed this question
Top Everex Computers & Internet Experts
k24674
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
