Question about Kicker Car Audio & Video
I just wired my kicker bass station to my alpine cde-133bt head unit but I have no bass from the sub and a blue light is lit on the subwoofer what's wrong?
simplemitch
  • 752 Answers
SOURCE: subwoofer works at high volume, doesnt work at low volume
You had the settings set incorrectly and overdrove it. The voice coil leads are burn't open. If you look at the little flexible braids by the terminals I'll bet they are black/brown and maybe even burn't in half. It's toast.
Posted on Sep 22, 2007
trintek
  • 111 Answers
SOURCE: subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Posted on Nov 19, 2007
zzedly
  • 300 Answers
SOURCE: bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
Posted on Mar 07, 2008
SOURCE: Kicker L7 10
I have an 04 L7, and recently it just stopped working in gereral. any way to test it? power lights turn on on the amps and i hooked another sub up to the amp but no problems. Someone suggest maybe voice coils blown?how can i check that? or how much to fix it? or would it just be easier to buy a new one and throw the other one out? thanks!Please send all comments to superchink15@aol.com thanks!
Posted on Sep 27, 2008
  • 191 Answers
SOURCE: My car subwoofers work, but theres no bass
turn them off and carefully push in on the cone (gently) and listen for scratching or scraping- push strait in and they should flow freely in and out if they DO without feeling or hearing scraping the subs are probably ok, next its either the amp is not powerful enough or the box is not soundly built, by that i mean its too small for the subs- is the box ported or sealed? if ported try plugging off the vent temporarily and see if bass increases if it does i would permanently seal the box
Posted on Mar 16, 2009
Alpine cde 133bt no sound
check trouble shooting methods on the manufactures website http://support.alpine-usa.com/products/documents/OM_CDE-133BT_EN.pdf
http://www.alpine-usa.com/product/view/cde-133bt/Specs
Hope this helps also check your wires make sure they match up
May 31, 2013 | Car Audio & Video
Hey names Nathan and I just got a kicker ZX300.1 and a I connected it to my kicker comp 12 and an alpine cde 102. So the problem is that the protection light flashes with the beat of the bass at high...
Your speaker wires could be shorting to ground at the subs or at the amp. You could be experiencing a drop in voltage when the bass hits. Check your power connection at the battery, fuse and amp. Check your ground connection at the chassis connection and at the amp.
Aug 19, 2012 | Car Audio & Video
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
Subwoofer for alpine cde-9843
In short, no.
The CDE-9843 cannot drive a sub of the type you mention without an amp, but you can fit a sub with it's own built-in amp.
As standard, the head unit has a basic in-built amp supplying 4 x 16w RMS at 4ohms but there is the facility via the unit's own menu to turn off the in built amp and use the output sockets as a pre-amp feed, but in reality if you want to drive an amp you'd be better off to start with a more highly specified head unit to begin with, even the next model up, the CDE-9845 is better suited as there are pre-outs for front and rear speakers.
User instructions are available from here.
If my reply has been of assistance then please return the favour by rating my answer.
Nov 09, 2009 | Alpine CDE-9841 CD Player
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Help wiring my subs and amp?
number 1 sub number 2 sub
I I
I I
I I
I I
I I
I I
to amp to amp speaker side speaker side
connect negitive from sub 1 to positive on sub 2 this makes it 4 ohms and especially with that amp you have it will still kick some hard hitting bass good luck
Apr 14, 2009 | Car Audio & Video
Subwoofer doesn't play through ipod, only radio and cd's
Hook up the remote wire from the head unit (grey w/ orange stripe) to the power antenna wire (blue) on the wiring harness adapter.
Jan 15, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
No sound from sub woofer Mutant MTSBP12 fiat punto 57 plate
Hi Mate
Just installed this Bass pack into mine today and I initially had no sound either.
Check all of the following.
- Make sure that you have a good earth to the chassis. (Check for green power light led on amp).
- Make sure that your remote signal wire (blue) is connected to the right out on the back of the head unit. If it doesn't have one, use the power antenna wire.
- Check inline and amp fuses, if either is blown, it's most likely a bad earth - clean up contact area/blot with wire brush/wire wool.
- Check the underside of your head unit to see if there's a switch to activate the pre-outs on the back of your unit.
- Check your owners manual about how to actually turn on the sub!! I have an Alpine unit and you need to turn it on from within the menus. There was also a seperate bass level setting.
- Carefully adjust gain and crossover until you get bass.
Hope this helps....If you get any more probs, give me a shout at obzy@blueyonder.co.uk
Cheers
Jul 08, 2008 | Car Audio & Video
Wires
Hi Gott Mudd,
I can relate to feeling it in the bones. You got the stuff to do it.  You should try the Alpine MP3 head units with bass boost, those are bad to the bone.
Wiring:
Amp to Speaker I like to use the code VC for Voice coil, and AO for Amplifier output.  Also + for positive.  If I say VC1-, I am referring to the first connector starting left to right on the Alpine Sub. Now I have not seen a Kicker KX1200.1 amplifier.  All I see are MRA, MRP, or PDX prefix on the part numbers. So take what I am saying as a guess. You may want to revisit looking at the model of the amp to be sure your giving the right information.
We are going for  2 Ohms. Paralleling the two subs, not the voice coils. The voice coils will be series.  Bridge the amp if necessary to get mono channel. only using AO+ and AO- for output.
AO+ to Sub1VC1+
AO+ to Sub2VC1+
Sub1VC1- to Sub1VC2+
Sub2VC1- to Sub2VC2+
AO- to Sub1VC2-
AO- to Sub2VC2-
Set your Crossover to LPF
Adjust the bass gain down to lowest until you test.
Set the Frequencies to midrange between 40 and 100hz
Your box can be ported or not. It depends on the space your have.  If you do not have much room, go Enclosed and build a box that the inside space is less than 1 cubic foot.  Make sure you give barely  enough clearance for the speaker to fit.  If you have room, Go with a box and vent it with a 3 inch Vent tube 10 inches long.
Oct 15, 2007 | Alpine Type-R SWR-1242D Car Subwoofer
Car Audio & Video Logo
152 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
