Question about Cameras
We have a sony HVR-A1E Camera, are using the AV connecting cable and unable to get it to connect to our tv play back footage. Can you help?
Just a thought but have you got the right format selected?
Try this;
Press 'P-menu' on screen, then select 'VCR HD/DV'.
Make sure that you then select either DV or HDV depending on which format you filmed in. The 'auto' function doesn't always select the right one!
Posted on Oct 28, 2009
How do I connect a field monitor?
Hi David,
I found a manual but not for your exact model....The link should show you possible ways to connect your cam to the monitor
Sony HVR S270U Operating Manual Connecting Monitor Or Tv
Hope this gives you some direction.
Thanks, and please rate if helpful!
Gary
Apr 07, 2016 | Sony Hvr-a1u 1/3" Professional Hdv...
I have a sony w110 DSC. My problem is that I cannot play videos on a tv when connecting with the AV cables provided
Hmm.. Make sure that your TV is set on Video (1,2 or 3) depends on which port you connected your camera. Can you view the pictures properly on your TV? If you can see the pictures/videos on your camera and then connect it to your TV, you should be able to see the pictures and the videos. Unless the AV cable is damaged/not working.
Oct 02, 2011 | Sony Cameras
I USE TO HAVE A LAPTOP AND WAS ABLE TO DOWNLOAD MY PICTURES WITHOUT PROBLEMS. NOW I AM BACK USING A TABLE TOP COMPUTER, I HAVE THIS OTHER CABLE WITH A YELLOW & WHITE MALE IN-PUT AND THE OTHER END FITS...
Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer.
You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number..
319698101 .... CODE (USB 5P) CONNECTION
Thanks.
Jun 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
I want to use my canon A 720 Is camera as a webcam, please guide
Welcome to FixYa.
You can use the supplied AV cable to shoot or playback images using a TV/computer.
1. Turn off the camera and the computer/tv
2. Connect the AV cable to the camera's A/V out terminal(open the terminal cover and plug the AV cable in all the way)
3. Plug the other ends of the cable to the VIDEO IN and AUDIO IN jacks on the computer/ TV.
4. Turn on the TV/ computer and switch it to video mode
5. Turn on the camera.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 14, 2011 | Canon PowerShot A720 IS Digital Camera
What camera will accept 119302c sd card to show on tv
There are literally thousands of cameras that will do what you're asking. As far as inexpensive Point & Shoot cameras, try the Canon SX100 IS. These use the SD card and come with an AV cable to connect to the TV. Stay away from Sony cameras. They use Memory sticks and compact flash cards. Be sure when you purchase a camera that it comes with the AV cable if you choose to buy a used camera on eBay or similar website.
Nov 04, 2009 | Bushnell 119302C Digital Camera
Unable to download pics on my Samsung L100
have you check if you are using the usb cable or the av cable. the camera will not show anything on the screen if you are using the av cable and connect the camera to your computer.
Jan 11, 2009 | Samsung L100 Digital Camera
Trying to play off-camera stored video, when replaced onto SD card in camera
Did you change the file name on the original video? Are you able to put the video back onto the camera? If you changed the file name, you can't put it back onto the camera. It also needs to be in AVI format which is the video format that the camera records in.
Hope this helps!
May 28, 2008 | Canon PowerShot S5 IS Digital Camera
Linking my canera to the TV to view the pic's
Playing Back images/Video Clips on TV You can also playback your images on a TV screen. Before connecting to any device, make sure to select NTSC/PAL system to match the video output system of the video equipment you are going to connect to Vivicam 5340s, then turn all connected devices off. 1. Position Vivicam 5340s on the cradle. 2. Match the docking connectors and carefully insert Vivicam 5340s until it fits in place. 3. Connect one end of the A/V cable to the A/V terminal of the cradle. 4. Connect the other end to the A/V input socket of the TV set. 5. Turn the TV and Vivicam 5340s on. 6. Playback the still images/video clips. The method of operation is the same as playing back still images and video clips on Vivicam 5340s. I hope this helps:)
Aug 24, 2007 | Vivitar ViviCam 5340s Digital Camera
How can I playback and edit the captured movies?
The movies can be played back on the DiMAGE Z3. They also can be viewed on TV by connecting the camera and TV via the AV cable. Playing back movies on PC is enabled by installing the QuickTime, ArcSoft VideoImpression Version2 (Windows only), and DiMAGE Viewer
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Cameras Logo
88 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
