Question about Philips 42PFP5332D 42 in. Plasma Television
42PFP5332D/37 blinking red and blue lights - Philips 42PFP5332D 42 in. Plasma Television
5 Suggested Answers
  • 52 Answers
SOURCE: Power Problems - won't turn on
first thing to do is determine if there is a blink code as that gives a direction for t/s. regardless, what you should do first is offload the y main and x main sustain boards from power supply one at a time as there is a common issue where these boards can cause load on power supply and if voltages come up with either one offloaded that board should be replaced before proceeding. if y main is the issue there is an upper and lower buffer board to left of that board and also should be replaced at same time as 3 boards complete a circuit and replacing one could cause damage to others.
Posted on Aug 18, 2008
  • 52 Answers
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Posted on Aug 19, 2008
  • 3 Answers
SOURCE: RED LIGHT BLINKS SEVEN TIMES
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
Posted on Aug 10, 2009
  • 8457 Answers
SOURCE: my philips 42pfp5332d/37 when i turn it on the
Power supply board is dead.Replaced the power supply board,that the board where the power a/c cord go into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jun 06, 2010
Have a Philips 42PFP5332D/37 TV. I just moved and after I plugged it in and hit the start on button. The blue blue comes on for a couple of seconds and turns into a red light that flashes 6 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jun 03, 2017 | Philips Televison & Video
Philips model: 42PFP5332D/37 The other day it clicked and the picture went out. The blue light comes on and it stays blue with no picture or sound
Your set need a thorough check-up. Contact the authorized service centre or an experienced service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Philips 42PFP5332D 42 in. Plasma...
My philips 42pfp5332d/37 when i turn it on the blue light comes on and it has no picture and just makes a clicking noise. If you look at the back you can see 2 green lights go on and off. it happened after...
Jun 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
Insignia 37 in lcd, trun on light gose blue
It is the main board failure, because Insignia TV has no error blink design.
May 10, 2010 | Televison & Video
Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
Aug 15, 2008 | Philips 42PFP5332D 42 in. Plasma...
Power Problem
Philips Problem
Philips 42PFP5332D/37 power problem.
The set blue light comes on, then then standby light comes on and flashes. no picture, no sound and no help from philips. Anyone knows the cause and possible solution? Help
Jul 23, 2008 | Philips 42PFP5332D 42 in. Plasma...
Philips 42PFP5332D 42 in. Plasma Television Logo
829 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
