Question about KDS Avitron 195TF Monitor
Faulty display on screen
The screen is narrowing in on both sides in a curve towards the center of the screen.I have this monitor for 2 1/2 years or so. What can be the problem? Tks Trini
  • 2 more comments
  • oletbird Mar 09, 2008
    Kds Monitor - Display pulls in on each side to somewhat of an hour glass shape . A tap on the side of the monitor restores it for varying lengths of time but is BY ** MEANS a fix . I don't think I know enough about it to get inside the cabinet to try anything.
  • Anonymous Jul 14, 2008
  • Anonymous Sep 12, 2008
    yes my screen is narrowing towards the center and I have to tap the desk so it coud go back
  • Anonymous Jan 11, 2009
    Tapping the monitor does fix it sometimes, as does turning it off and on. I will have to open it aand check solders
  • 105 Answers
Your monitor has a fault in the pincushion correction circuit. Most likely a bad solder connection, a failed diode or capacitor. I recommend you have a repair facility fix this one.
Posted on Sep 04, 2006
SOURCE:
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
I have a 2 year old Toshiba 32
Your panel is defective.Not worth repair.Try calling Toshiba customer support and see if they will help you.
Sep 28, 2009 | Toshiba Televison & Video
Dell Monitor E207WFP Picture Not Centering
Try another monitor on the PC, see if that helps.
If it does, the monitor is faulty. Try resetting it to fctory settings.
If it isn't, it's probably your graphics adapter, or something in between.
First check the vga cable, then reinstall the graphics driver.
I hope this helps,
Yannick.
Jun 17, 2009 | Dell E207WFP LCD Monitor
Screen display
You have control buttons for the OSD either on the bottom or the side of your monitor.
Push and enter the set up and push buttons until you see the arrows that move the screen up or down, right or left.
Your model may have one of the buttons marked automatic. If so, pressing that one will center the display on your monitor.
Let us know if you still have a problem!
Sirwriter
May 13, 2009 | ASUS Computers & Internet
Screen is distorted
hi there, Below the monitor, on the center are option button, you can explore that in adjusting your screen display. You can widen the display, or tweak it depending on the angle that you need to. Just press the center button and choose from the menu.
Oct 25, 2008 | Dell E771p 17" CRT Monitor
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Screen image display distortion
Hello.
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
Problem with my Dell E771mm 17 in.CRT monitor
How far from the sides is the image? If it?s just an inch or two you can use the monitor adjustments to expand the image to the edge of the screen where it was previously. If its too far in then the only option is to have it repaired. You didn't mention where you are but in the US even a minor monitor repair that involves at tech opening the monitor is going to cost at least $45, perhaps more. That?s a lot of money for a monitor worth about $100 new so a new or used monitor may be a more cost effective option for you. Let us know if you have any other questions and please don't forget to rate this post.
Apr 04, 2007 | Dell E771p 17" CRT Monitor
KDS Avitron 195TF Monitor Logo
556 people viewed this question
Top KDS Computers & Internet Experts
Thomas F. Schneider
Siul Oyaratgam
Steve Allison
Steve Allison
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
