Question about Panasonic PV-C1323 13 in. TV/VCR Combo
How to play the DVD player I have hooked up to my Panasonic PV-C1323. Does it need to be on a certain channel?
  • 3 Answers
SOURCE: Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Posted on Dec 30, 2008
ruben_barrer
  • 117 Answers
SOURCE: Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Posted on Jul 23, 2009
rulds2008
  • 3866 Answers
SOURCE: ARE MY PANASONIC PV-DM2799, AND MY PANASONIC
You can get a converter box for these for over the air programming but if you got satalite or cable you are FINE!!! it will work great
But they do not have digital tuners no.
Please do rate the answer thanks
Posted on Aug 19, 2009
  • 476 Answers
SOURCE: Panasonic pv-c1350w channel/clock auto set
You are probably talking about the main menu that appears when the TV is taken off the AC power outlet, to get rid of this page just turn the tv off and on again and it should give you access to what ever channel was tuned before, if your game console has an RF out, your TV should be set to channel 3 ir 4, if the console has composite outs the change the channel until the TV goes to Aux in or Video in. Retrevo.com has an instruction manual available which you can download free, just in case you need more informantion, if the channel keys do not work, then you may have to get a universal remote ,they are fairly inexpensive and will come in very handy at least for the basic functions or just have theTV worked on.
Posted on May 12, 2010
gopakumarg43
  • 74459 Answers
SOURCE: Model PV-C1323 -- I am
Hello
If you have your Panasonic tv locked there is one way to open its lock.
Put it in standby mode and then press the POWER and ACTION buttons at the same time and then turn the power off by TVs front panel power switch. The set should reset to Factory defaults and reset the V-Chip.
Then switch on the TV. Ok.
Posted on Nov 17, 2010
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
How to hook up a DVD to this tv
Find the video input. This is usually located at the back or front or side of the TV. There should be a video and audio (sound) input there. You can hook up your DVD player here. Please use the proper cables for it (use RCA cables). This is usually color coded. Your DVD should have come with it.
Hope I have been of assistance to you.
Thank you.
Nov 08, 2009 | Panasonic PV-C1323 13 in. TV/VCR Combo
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
Panasonic PV-7451 VHS
I don't recognize your first problem.  The "light to dark" issue I believe is intentionally engineered (mine does it too); it prevents recording DVDs on to tape.  Try running the DVD player directly to the TV.  Radio Shack used to have a box that would correct this issue too, you might check there.
T. R.
May 18, 2008 | Panasonic PV-7451 VHS VCR
Hooking mini dvd camera to play through the television
tape needs to be played from camcorder only w/ a/v cables to tv-no other way unless you make dvd on computer first
May 13, 2008 | Video Cameras
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Panasonic PV-C1323 13 in. TV/VCR Combo Logo
19 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
