Question about Sharp Televison & Video
I've got a Sharp VC-MH704 Video recorder which has stopped working. The fault is that when a cassette is inserted the "insert" arms seem to be out of sync. When the cassette drops down, two arms take the tape around the head, then the drive roller drops down before the third tape arm moves towards the drive roller. This means that the tape does not get driven by the drive roller and the video will not play. It is obvious that the third tape arm should take the tape beyond the drive roller -but this doesn't happen. Any ideas? - it appears to be a mechanical failing rather than anything elctronic. Thanks.
  • 975 Answers
PLEASE DO NOT RETRACT IT BACK manually doing so ,will DAMAGE more the unit ,what you should do is plug the Video Camera AC plug and press the EJECT BUTTON , OR TRY turn in ON & OFF , TO SEE if it works.....
Posted on Apr 18, 2008
SOURCE: My Panasonic NV-SD270 video player
when the loading mechanism have a trouble and did not thread the tape properly , the eject mode commands primarily coz the tape in sensor activated properly
Posted on Apr 29, 2008
swami nathan
  • 208 Answers
SOURCE: I have a Toshiba TV
I am giving you the link where there is a manual which contains each and every step for
1. Connections
2. Basic set -up
3. Recording
for your D-VR16SB recorder.$file/D-VR16_OM1.pdf?openelement
Make sure you follow these steps. You will definitely succeed.
Hope my info fix your problem,
Thanx for using fixya,
Waiting for your comments.....
Posted on Sep 26, 2008
  • 3422 Answers
SOURCE: when inserting vhs video tape
Please reset your unit.Just unplug all the cords from the back of the unit and the power cord as well for 1 hour after that reconnect the cords and turn on.the tape will come out.
Let me know the result
Posted on Oct 13, 2008
  • 65 Answers
SOURCE: heads and tape path need cleaning
if you don't know what u are doing u shouldn't mess with video head. U can easily damage the head. If cleaning tape does not work have tech do it. Should be relatively cheap.
Posted on Apr 22, 2009
Can anyone supply me with the common commercial type number, JEDEC number, for the power supply output transistor in the Sharp VC-H982U video cassette recorder?
Type "Sharpe VC-H982U Service Manual" into Google and you will see a free PDF of it. That should tell you the number!
Dec 27, 2015 | Sharp VC-H982U VHS VCR
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
I am looking for the user manual for a sharp vcr model vc-mh704
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Jan 19, 2011 | Sharp Televison & Video
Inserted a cassette, get the message "cannot record cassette" "protect tab". A little grey piece (probably the protect tab) fell out the camera when I set it down. Not sure where this...
On the mini-DV tapes I have, the protect tab is a slider- it does not come out of the cassette. If you look at the back edge of the tape, where the long label goes, the protect tab is at the right hand end. When it is set to prevent recording it will look like a little square hole, but there should be a tiny edge of the tab showing (mine is green) which you can pull across with a fingernail or sharp object to cover the hole and allow recording.
Nov 29, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp Viewcam VL-AH151U keeps saying "eject cassette" why is that? How or where can i send this to get fixed?
Assuming the record tab is in the correct position, download the manual for the VL-AH150U, very close to the 151U.
Page 10 of the manual shows the normal reasons for the "eject cassette" message. If not, I would call Sharp support at
1-800-BE-SHARP (237-4277) for referral to a local repair center.
Let me know if this helps.
Jan 18, 2009 | Sharp Viewcam VL-AH151U Camcorder
VC recorder keeps on driving
I beleave your sensor that tells the player weather a tape is in there or not needs replaced ~ It sounds like it doesent know the tape is not there aand will not shut down! (replace tape sensor)
Please rate my answer and help keep this site free!
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic video recorder malfunction
It sounds like you need a service manual - it tells you how to remove stuck tapes etc.If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
Televison & Video Logo
47 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
