Question about Lock Technology (LT 940) Gas Tank Fuel Pump Removal Tool 940
Need information on how to remove fuel pump for a 1996 audi a4
How to remove this
    Brigadier General:
  • 6,468 Answers
I think you can get to that from under the bottom of the back seat pull the bottom out and look for a bolted down round cover
Posted on Mar 30, 2012
Which one is the relay for fuel pump for audi a4 -1.8 - 1996 model- non turbo
relay no 6 in the fuse box under the dash on the drivers side
fuse no 6 is the last fuse on the right of the bottom row
Nov 16, 2016 | 1996 Audi A4
1996 audi a4 fuel pump @ or fuel pump relay
It would be easier to run a hot wire from the front to see if it runs.
Normally you would jumper the pump relay to test the pump.
Oct 03, 2012 | 1996 Audi A4
AUDI A4 1996 CARS BEEN STANDING FOR 6MTHS NO FUEL COMING TO ENGINE
mcdevito75 here, The electric fuel pump in the gas tank may be stuck, try rocking the car side to side with your hip to loose the float arm, Check fuse too, even try turning the key on / off a few times to get the fuel pump going.
May 02, 2010 | 1999 Audi A4
I need to change a petrol pump on A4 1996 model can someone guide me on how to do this
You will need to disconnect negative battery cable. Then jack up rear of car. Disconnect wires to tank, disconnect filler tube, disconnect return hoses, then disconnect support straps to tank.
Then support tank with a jack and mabey a helper. Remove mounting bolts holding tank up. Lower gas tank and pull it out. Then with a BRASS and only a BRASS punch and a hammer, knock the ring on top of tank counter-clockwise to until it is loose and you can remove it. Then carefully pull out the sending unit and pump and disconnect the two of them.
Reverse procedure to re-install
Apr 20, 2010 | 1996 Audi A4
Taking out 2001 Audi A4 Fuel Pump
it is just a matter of unscrewing the cover in the trunk,removing the wires,then unscrewing the pump cover.make sure the fuel tank is not empty as an empty tank is highly explosive.
Mar 27, 2010 | 2009 Audi A4
Replace fuel pump audi a4 quattro 1996
The locking ring for the fuel pump can be released and reinstalled using two large combination spanners (wrenches) with the open end against the locking ring tabs and the spanners held in against each other to form and 'X'. Push/pull on the ends to remove or install the locking ring.
UNDER NO CIRCUMSTANCES USE A CHISEL OR HAMMER TO REMOVE THE RING AS THERE IS RISK OF EXPLOSION!
Be sure to perform this operation in a well ventilated area with all windows down and the battery negative cable disconnected.
Oct 31, 2009 | 1996 Audi A4
Winshield washer pump has stopped pumping on 1996
Sounds like pump alright Unbolt tank from car and pump should be screwed to bottom of tank Another way is fit a universal inline washer pump Up to you whether you want to keep your car original
Oct 22, 2009 | 1996 Audi A4
Looking for a fule pump on my 2004 audi a4 avant 1.8t
If you are looking for it's location,It is inside the fuel tank.
Jan 10, 2009 | 1996 Audi A4
1997 Audi A4 B5 fuel pump
what makes you think its the fuel pump.......explain your problems (codes if you have any)and i might be able to help you......please give a good description of your fault please
Nov 11, 2008 | 1996 Audi A4
Lock Technology (LT 940) Gas Tank Fuel Pump Removal Tool 940 Logo
Top Lock Technology Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Lock Technology Plumbing Expert? Answer questions, earn points and help others
