Question about Panasonic CT-32SX12 32" TV
TV failure Re ; Panasonic CT36SX31E TV Tv was turned off and there was a electric power failure at the same time,fuse had blown off after replacing the fuse picture came and faded slowly away now when switched On power light RED comes on and there is light at the back of CRT and it goes away and power light goes OFF. Please let me know what I should check in video signal path? or is it T551 Flybackor is it L board CRT socket or T1551? Please let me know where can get service done and its costs including spares? I live in Hackettstown NJ07840 Regards
  • 81 Answers
I would say it is in the power supply circuit. check the 145 v line I do not suspect the problem in the video section.The 145 volts feed to the flyback.
Posted on Jun 11, 2007
Will not turn on, no blinking lights, power coming from cord is good
Sounds like the power supply board is dead. Probably has a blown power line fuse on the board. A power surge will sometimes blow the fuse and protect the board from damage. Replacing the fuse will restore the TV if this is the case. Most times though, the supply has a blown part that causes the fuse to blow and your only option then is to replace the board.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
Jan 29, 2013 | Panasonic TH-C42HD18 42 in. Plasma TV
TV WONT TURN ON
Got it fixed. Removed back off tv and found the fuse right where the cord enters. Removed fuse[didn't look like it was blown] and got new one from radio shack, installed and now the tv works. That was all it was. Thanks again
Apr 05, 2009 | Panasonic CT-32SL14 32" TV
Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Nov 04, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Big screen tv broken
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Dec 23, 2005 | Panasonic PT-65WX51 65" Rear Projection...
Panasonic CT-32SX12 32" TV Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
