How do I record with a Philips cdr 770/17 - Audio Players & Recorders
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Audio Player... Master
  • 102,366 Answers
The recording instructions begin on page 17 of the manual.
Posted on Feb 23, 2012
  • 112 Answers
SOURCE: philphs cdr770
A chip on the PCB under the drive is overheating.
Posted on Dec 07, 2007
SOURCE: trying to find cd to record for a philips Cdr 770 cd problems
Open the unit (if you dare) and change the jumpers on the back of the playback unit. Now you can also use normal CDR's.
Posted on Mar 13, 2008
SOURCE: Wrong disc
You need AUDIO cd-r or cd-rw's
Posted on Jun 29, 2008
  • 86 Answers
SOURCE: cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Posted on Feb 13, 2009
SOURCE: Philips 765 CDR - twin deck
Remove the 765's casing. If you don't have a star shapped screwdriver use a flat head which sits tight in the screwheads diagonals. Once removed, observe the 765's driver chip which sits behind the recording deck mechanism of the left hand deck. With the power cord disconected carefully remove this chip by gently working a flathead driver between the chip and it's base (the chip is not soldered to it's base but take care not to bend the pins) Once removed, power up the unit for a few seconds making sure that you do not touch the live internal workings. Remove the power cord again and switch the power button on for a few seconds(with no power chord attached) to allow the units capacitors to discharge fully . Gently replace the driver chip. Replace the cover and switch the unit on again. The unit should reboot and the gremlins should be gone.
Posted on Dec 25, 2010
For many years I bought the CD-R Audio. Special optimized for my Philips recorder (record/rewriteable). Now suddenly my shop tells me that these disks are not langer available. I'm desperate! Please...
Your shop is FOS. What's so special about them regarding YOUR recorder? CDR-A's that conform to the Philips standard are very common.
Web search "cdr audio". I buy mine in bulk on eBay.
Jul 26, 2011 | Philips Audio Players & Recorders
My "Philips CDR 870" keeps
It means the disc you're trying to record onto is for DATA, not AUDIO, which it must be for a consumer recorder. See page 10 of the manual for Additional Information.
Jun 22, 2011 | Philips Audio Players & Recorders
Phillips cdr 200 recorder, just recorded 13 tracks with time left over on sony brand recordable cds for music. i switched from analog to digital to finalize and it took 4 mins however RECORDABLE still...
It sounds like it didn't truly finalize. Try finalizing it again since the 'recordable' status implies it still qualifies. You have to press RECORD immediately after FINALIZE.
The Philips directory lists a few CDR200 models but the documentation contains directiosn for CDR765.
http://www.p4c.philips.com/files/c/
for example...
http://www.p4c.philips.com/files/c/cdr200bk/cdr200bk_dfu_aen.pdf
If for some reason you ever want or need to extract music from a non-finalized CDR or CDR-W, try loading it into a standard DVD player. Without a TOC the player won't be able to display track info or navigate to individual tracks but it MAY play it straight through anyway and you could digitally capture all or part of the output on another CDR. Just be aware that if the original is rewriteable and has old data beyond the new data you will crash into it without warning at the end of the new data, so be ready to pause your copy at the appropriate time.
Apr 07, 2011 | Philips Audio Players & Recorders
I have a Philips CDR 778 audio cd recorder. I try
you prbly need to replace the burning laser which i would imagine is still avail however the cost of the laser may not b a prblm but fitting it could b
Apr 17, 2010 | Philips CDR778 2-Disc CD Recorder
I nead a new manual for a phillips cdr 775 dual recorder
http://www.usersmanualguide.com/philips/home_audio-video__cd_recorders/cdr775_00
Choose your specific model and language. Downloads in pdf format.
Good Luck,
BB
Jan 05, 2009 | Philips CDR775 2-Disc CD Recorder
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
Not reading blank cdr audio disks to record onto..
Will it read audio cd's? Sounds like you need a new laser unless you have access to a philips COMPair system to diagnose / realign it.
Dec 12, 2007 | Philips CDR600 CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
101 people viewed this question
 Grubhead
Grubhead
