Question about Pool & Spa
LA SPA UNLOCK
IT IS LOC FLO NEED TO KNOW HOW TO FIX
2 Suggested Answers
ynogami21
  • 670 Answers
SOURCE: coleman spa horizon 400 flo
please try to double check the water level. Alot of these spas are very sensitive to the water level. One other thing you can check is the terminal board connections. Some times these burn out. Let me know if any of these helps.
Thanks!
Posted on Aug 21, 2011
When I turn my spa on the pump sounds like it is laboring real hard then kicks off, does not trip breaker, then after about 20 seconds it does it again so on and so forth
That's the thermal overload shutting the motor off. It generally indicates a problem in the bearings or motor windings. The usual fix is to replace the motor.
Nov 02, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Need 2 complete replacements for a FLo Master spa pump 06630397-2 -do you carry and how much?
best is to see if they can be repaired, you need a experienced pump repair shop with free testing, these are hard pumps to work on. or keep a eye out on craiggslist.
Sep 29, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
The FLO is lit up on my Pro-form restoration 5.1. how do i fix it?
The error code FLO indicates that there is NOT enough water flow through the system to operate the spa and make the heater turn on.
Check your spa filter by removing it. If the heat indicator comes on then you can be assured your filter is too dirty.
If the heat indicator light does NOT come on after removing the filter then you need to check the PRESSURE SWITCH by by-passing the switch and see if the heat indicator light comes on. If it comes on after jumping the two wires together that go to the pressure switch then you know you have a bad pressure switch.
Also, check the gate valves on either side of the pump to make sure they are completely up and you have good water flow.
Rod
US Parts Center
888-521-6183
Feb 06, 2013 | Pool & Spa
How do you change the bearings on a flo-master Xp2 spa motor?
First, you'll need a bearing puller and maybe a couple of other specialty tools. The bearings are not expensive, but the experience can be.
In the event that you successfully get the bearings changed, there is a high likelihood that the races have been damaged, especially if the end bells are made of aluminum. This means that your motor will sound remarkably similar as it did before you started this project.
If you choose to tackle the job, more power to you, but there is not enough space here to walk you through it. The standard fix is to replace the motor. Thirty minutes, long term solution, done!
Jan 29, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My pacific hot tub has LOC on the display and i cant adjust the jets or temp. Is the display locked and how do i unlock it?
Mike,
Yes LOC is a standard topside lock code.
Try these common unlock codes,
Press & Hold Jet Button for 6 seconds
or
Press & Hold Temp Up & Temp down for 6 seconds.
Possibly your jet button is faulty i.e. it is broken internally or when it is pressed the button sticks in the on position and locks out the panel.
If those common codes don't work let me know which brand/topside control your spa has and I will get a more specific answer.
Jan 16, 2012 | Pool & Spa
Where cani find replacement thru-bolts for an Aqua Flo XP2 pump?
A local motor repair shop would have the thru bolts. If you have at least one good one, you could match up the size, and cut soem threaded rod. Most motors this size use either 8-32,10-24,or 10-32 bolts. You can buy threaded rod at hardware store. Try to find galvanized, to prevent corrosion, or paint the part inside the motor if you cannot.
Aug 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Need to know where wire that comes from controls on hot tub connect to pump at?
Thank you for posting your question here on Fixya.com.
Assuming you have a standard white, black red, green cordset, green to ground, white to common, red to high and black to low. If the speeds are ‘reversed’, interchange the red and black leads. You likely have an AOSmith motor which will be labeled 1, 2, ¾ on the terminal board. 1 is common, 2 is high and ¾ is low.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 15, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pump was working fine yesterday popped the breaker
Hi Mohn,
Don't know your geographic location, but where I am we've been in the single digit temperatures for three days. Everything that can freeze has frozen.
If you are in a similar area, even though the water in the spa (I'm assuming the spa pump is being used on a spa) is heated, the pump housing isn't. If it iced up, it could very well cause the problems you describe.
Comment back with some more detail before I continue down what might be the wrong path.
Best regards
Mike
Dec 11, 2009 | Aqua Flo 2 HP Aqua-Flo Pump: 2" in/out,...
Pool & Spa Logo
95 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
