Question about Price Pfister Plumbing
Set water temp
How to set water temp on a one handle price pfister tub shower valve
Remove the handle, find the plastic disk with teeth, pull out disk and turn to left for hot, right for cold, set disk back in place, then replace the handle, repeat as necessary.
Posted on Feb 22, 2012
  • 171 Answers
SOURCE: Pull out shower handle
HI jazzman45,
I'm Harvey the Master Plumber.
Your problem is: Pull out Price Pfister valve screw in the handle has separated from the valve. How do you pop the chrome cover to access the small screw to reattach to the valve? You don't want to just pry it off.
If you really don't want to pry it off then ask someone else to do it. That's all there is to it. Just be carefull not to scratch the chrome. From now on any time the handle feels loose retighten before it falls off and save yourself some grief. You'll find it's really easy.
Feel free to contact me again
Don't forget to give me a rating on fixya before you leave.
Harvey your Master Plumber
Posted on Oct 16, 2008
blueextc3221
  • 15935 Answers
SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Posted on Dec 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Posted on Feb 13, 2009
  • 21 Answers
SOURCE: Water came out both shower head and tub spout (even w/o spout)
The shower valve is clearly mark "UP" when you look at it from the front.
Posted on Nov 27, 2009
Testimonial: "That's right"
  • 20 Answers
SOURCE: Sensitive Temp adjustment through shower.
Pull the trim off of the valve and you will see a 1 inch diameter flat screw, unscrew that and clean it out and try it again. If rinsing it doesn't work you may need to replace it. It is called a balancing caulk.
Posted on May 02, 2010
How do I remove a Pfister Marielle metal lever handle?
Bear with me, please. Adjust the temp at the physical valve?
Interesting at the least. Never seen or heard of that. They come up with something new everyday. I'm going to follow this for my own benefit. Thank you. And good luck. - Ned
Jul 23, 2014 | Price Pfister Home
I have a price pfister a112.18.1 shower only (no tub), single-handle. It is leaking from the shower faucet. How do I repair?
You have to turn water off to shower and remove handle then cartridge lock ring then there are two washers and srpings that can be popped out with small screwdriver.Lowe's has replacement springs and washers ,be sure to mark position cartridge was because that is very important to reinstall the same way it came out.
Jun 09, 2011 | Price Pfister Plumbing
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Mar 28, 2011 | Price Pfister R89-7PC0 Chrome Portland...
Hot watwer leaks from the hot side of the facet
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
May 21, 2010 | Price Pfister 01-31xa Shower Head, Tub...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
Water leaks out of shower head during tub use. valve was installed properly
The pipe to the tub spout is either restricted or the valve was placedd too high causing some of the water to come up and out of the shower head instead of it all flowing out of the spout.
Nov 12, 2009 | Price Pfister R89-7PC0 Chrome Portland...
I have a Price Pfister Model no. 808 DK00 single handle bath tub/shower faucet. I am only getting hot water coming out when the handle is turned on. This problem just started. It was working fine for about...
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
Sep 17, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Feb 27, 2009 | Price Pfister 01-111 Shower Head, Tub...
Plumbing Logo
137 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
