HP my display
The warning on new HP w2007v monitor reads thus: HP My Display has encountered a problem and needs to close.
Further info includes error code 00005c56 App name:dthtml.exe
This warning appears each time I boot up. Can you help, please?
  • Anonymous Jan 29, 2009
    I've been getting the same error since I installed my new monitor, HP w2448hc. I took both my monitor & tower into computer store to get the error fixed. The tech said it was because I used the disk that came with the monitor when installing it. That I should have left Windows find what it needed without that disk. He couldn't fix it.
pishta68
  • 593 Answers
SOURCE: PC monitor not lighting up for around 10 mins
Check the capacitors on the power supply board inside the monitor. They malfunction, heat up, leak or pop and stop doing what they are designed to do, smooth out the power supply to the inverter and display board. You can replace these simply by buying the correct farrad, voltage and temperature rated replacements online for about .30 a piece or go to radio shack and spend 1.50 a piece. You can use a higher voltage like 35V instead of 25V but try and get the 105c rated ones to last longer in the hot P/S environment. My bad ones were 470 micro farrad, 25V and 105c rated and I had 4 out of 8 pop or bulge.
Posted on Apr 08, 2008
ODCaloney
  • 260 Answers
SOURCE: I keep getting an error
Unfortunately it is time to upgrade the operating system.
Posted on Mar 19, 2009
SOURCE: i am not presently using
This problem is widely reported and the only solution I know of is to rename the file in Windows/system32. BRSVC01 will no longer attempt to load at start-up. BRSVC01 loading at start-up is apparently unnecessary. Renaming can always be reversed if you encounter any problem.
Posted on Apr 17, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
nyilasrobert
  • 627 Answers
SOURCE: At boot time appears message 'Device Monitor Appliaction (mispell
try this:
1. download combofix and follow his steps (don not agree with recovery console)
link is here : http://www.combofixdownload.com/
notify me if problem is resolved
Posted on Jun 29, 2009
Why can I not use 2560x1080 (only 1920x1080)?
DisplayPort is supposed to support very high resolutions and unless they really compromised the hardware in the monitor, it's unlikely that the DisplayPort input isn't supporting the resolution.
A note about "drivers": Monitors used to come with "drivers" back in the Windows 98 days. Monitors never actually had "drivers". The monitor is a totally separate entity that only receives image signals from the computer. The so-called "drivers" were actually information files that told the computer (and its display system) what resolutions the monitor was capable of. In all Windows versions after XP, monitors have been able to identify themselves over the advanced display interfaces and the Windows databases have included all monitors. Today, Windows 7 and 8 dynamically search their online "Windows Update" service for more information files if they encounter a new monitor. Suffice to say, if your system identifies the monitor by name and model number, it has all the information it needs about the monitor.
Unfortunately, the more likely possibility is that the display system ("video card" or onboard video chipset) in your system doesn't support 2560 resolution via DisplayPort. If it doesn't, all the cable adapters in the world aren't going to help you. Go look up the specs of your computer on the manufacturer's web site and it'll list the particulars of the display system (at least the make and exact chipset model number). If the computer specs don't list the supported resolutions, then go look up that manufacturer's chipset info and see what the supported resolutions are under DisplayPort. Alternatively, post detailed make/model info for your computer here and we can help you find the necessary information.
If the display adapter supports it, DisplayPort straight through (no cable adapters) will be your best bet in displaying it. But if the Windows display adapter properties resolution selector doesn't list it (and it identifies your monitor by correct make and model), then you may be out of luck.
Answer some of the questions I've posed here about computer and video adapter models and we'll help you verify the truth about your display system.
Apr 27, 2014 | ASUS MX299Q - LED monitor - 29" -Full HD -...
Using notebook display and external monitor: HP Pavilion zd8205us primary display is garbled, secondary display is clear and good, It doesn't matter which display device you set as primary or secondary
try to switch the blue VGA cable that is connected from the laptop to the external monitor. You may also restart your laptop and set aside the external monitor to check if the laptop is still experiencing garbled display... If it still is, then it is a monitor issue and need to address to HP personnel by calling HP hotline. Otherwise your issue will be resolved by simply doing that..
Nov 14, 2010 | HP Pavilion zd8000 Notebook
Monitor turned green
There should be adjustment buttons either on the front of the monitor on the computer itself. Then your can try taking the green out.
Dec 05, 2009 | HP W2007 Desktop Monitor
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
I have a HP Pavilion laptop ze4900. Every time I move th screen, the display either goes off completely, or it goes vey dim and I cannot read anything from it. The only thing I can do to get a display
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Computers & Internet
Confirmation
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
VISTA:The NTVDM CPU has encountered an illegal instruction
The link below is a step-by-step troubleshooter from the Microsoft website. You'll just need to follow all the instructions on the site and you should be able to fix it all by yourself. This seems to be a common error with windows.
Troubleshooting NTVDM and WOW Startup Errors
Sep 10, 2008 | Computers & Internet
Monitor problems
It is possibly your video card that is having the fits. Try replacing your video card or have your CPU checked... It is not a problem with the monitor, rather a problem with the computer...
Mar 10, 2008 | Computers & Internet
Resolution
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Getting an display in the printer.
If you have the manual there is probably a section about this. It does sound like some parts may be wearing out and the printer is asking for new ones. Check out this link: http://www.printertechs.com/tech/maintcount.php A snip from the info there: If the display panel on your HP laserjet reads "perform printer maintenance", "perform user maintenance", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count. For example the laserjet 4000 has a 200,000 page maintenance interval. Once you reach 200,000 pages the error message appears and you need to reset the maintenance count to zero to make the message go away.
Jun 15, 2007 | HP LaseJet 4350dtn Laser Printer
Computers & Internet Logo
277 people viewed this question
David Payne
David Payne
