Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Cornelius ice machine compressor AC-500-ss-mh
AK160AT-032 compressor or replace one that I thank
  • 3 Answers
CORNELIUS AC-500-SS-MH COMPRESSOR. Cornelius tech dept informed me that the compressor for this model is obselete and they did not have a replacement to recomend. Also the tehnical dept could not even find any listings for this model. It is a old version of icemaker that uses R22. The compressor as best I can find is a 3/4 hp, 6250 btu unit that supports a 20 degree evaporator temperature. I have done a lot of web searching and cannot find a suitable replacement in any brand.
Posted on Jul 13, 2012
My kml 250mah stopped makinr this condition?g ice after descaling. what is a possible cause fo
The valve that you turn to clean the area in between the plates has a small micro switch. This prevents the compressor from running in cleaning cycle. If the compressor is running, there is another issue.
Jun 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Have a Hoshizaki Commerial Ice Maker KM-630MRB that quits working when the temperature outside gets below 32 degrees. It starts to beep 3 times and we have to shut it off and reset it when it warms u
Well aside from jacking the machine up and putting another in its place, the only thing left is the electronic thermometer/thermostat that should be sensing the ice and not the outside temperature. By the way, if you spend more than the machine is worth think about another one.
Jan 13, 2013 | Hoshizaki Freezer Commercial Ice Machines...
I have a hoshizaki km 255bah compressor start then quits
Is the compressor overheating when this happens? Feel the top of the compressor when this is happening and tell me if the top of the compressor becomes extremely hot to the point that you cannot keep your hand on the compressor. Reason I ask you to do this is that it is possible that the compressor is short cycling because of a defective start relay and/or run capacitor. Let me know if the compressor is overheating of simply turning itself off. I will post a service manual if interested but would like to e-mail you the service manual for your Hoshizaki KM-255BAH because of copyright issues. You may contact me HERE if you like. Thanks Sea Breeze
Nov 21, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Why is my ice machine compressor over heating
usually from not enough refrigerant in the system. compressor overworking. excessive heat could also be from the compressor being bad such as bad valves. should be checked out by a service tech as this could involve removing freon to make repairs.
Oct 13, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Hi i have km-320-mwh hoshizaki ice machine, this machine is discharging water in drain continuesly except when it is dumping ice is this normal ...too much water is being lost please help many thanks...
By looking at the model number it is a water cooled unit. It will dump water down the drain continuosly as that it how it cools the compressor. If it was a MAH it would be air cooled and no continuos dump of water.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have ice machine hoshizaki km 500 mwe and is not making ani ice what can i do
I see this is from several years ago. if this is still an issue, let me know and I will try to help.
Jun 30, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice machine
3 beeps. hoshizaki replacing txv
Dec 21, 2007 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
258 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
