Question about Sony KP-57WS500 57" Rear Projection Television
Red flashes on screen
Screen flashes red multipal times and shuts down power
  • 2,326 Answers
Click here to find the info on how to fix your TV. Click on the website link and follow the instructions to the "T".
Good Luck.
Posted on Oct 28, 2008
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
When powered on, automatically shuts off with red flashing light.
you can claim the repair on your home insurance policy as FUSION
Sep 13, 2009 | JVC AV-27920 27" TV
No red in the image on the screen
The adjsutment that you turned down was the G2 voltage to the red tube which is just a temporary fix for a CRT which has a short developing in it. Try turning up the red adjustment again only slightly to see if the red CRT ( tube) will light up
if it does and then the set shuts down its most likely the red CRT which is bad . If it lights up but you get retrace lines but doesnt shut down it possible that its the CR board ( Red CRT Drive Board) which is at the very bottom of the red tube.
May 26, 2009 | Sony KP-51WS500 51" Rear Projection...
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony projection big screen
does the led flash when you try to power it up? If so let me know the number of flashes. From your description I would suggest 1 of 2 things happened. (1) The Convergence amp ICs have shorted and blown the 5 amp fuse on the G board, or (2) the red CRT has shorted shutting the set down. Check the fuse and if blown replace the fuse and disconnect the Red CRT PC board from the RED CRT and try powering up the set. If it powers up without shutting down then unplug the set and rehook the RED crt pc board and try again if it shuts down the reds shorted. But if it still wont start with the CRT unhooked or blows the fuse Change the Convergence ICs
Apr 06, 2008 | Sony KP-57XBR10 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
112 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
