Question about Fujitsu Heating & Cooling
Cannot turn on the Air con
Hi, I got a leak on my AirCon, hence I decided to wash the air filter myself. I turn the power off (there's a switch on the AC) while taking the air filter off. Now it seems I cant turn it on, no light no sound at all. Tried to turn on both using the remote and pressing the manual auto button in the AC. I also tried to find a switch on the AC, but after removing the cover, doesn't seems like there's another switch or button that I can tweak, only manual auto button and power on off switch. Hope you guys can help me with this :(
  • vanhalla666
    vanhalla666 Feb 22, 2012
    ow, btw, i checked the breaker, and its all ok.
    Tried to turn off the breaker for few minutes, and then turn it on. but no help.
  • 499 Answers
Check the door switch on the filter door.
Posted on Feb 25, 2012
What is Chemical wash process in AC maintenance Service?
Chemical wash process in AC maintenance is the part, in which the technician cleans every part of the AC with the use of the specific chemical.
This service includes:
1. Vacuuming of drainage system
2. Tightening electrical contacts
3. Cleaning & checking air filter, front panel & cover
4. Checking, deodorizing and purifying filter
5. Cleaning & checking indoor evaporator coil
6. Cleaning & checking indoor drainage tray
7. Aircon gas top up(chargeable, if necessary)
8. Checking fan bearing and lubrication (if necessary)
9. Checking compressor suction and discharge pressure
For more information, you can refer air conditioning chemical wash.
Jul 13, 2017 | Washing Machines
Audi TT 225 aircon condenser slight leaking from top.
Hi Andy
As Roger said take it to an AC specialist and have it checked, it will probably need re-gassing. AC gas leaks show up as an oily substance.
Regards Colin
Apr 15, 2014 | 2002 Audi TT
My panasonic ceiling aircon model cs-d24db4h5-1 timer light on and not cold.
is your filter dirty? i could see it stoping if the filters dirty. check the filter and if that is not it take it into a shop or send it in. if it cost's more to fix it just forget about it and get a new one good luck.
Jun 24, 2012 | Panasonic CW-XC104HU Air Conditioner
My machine half filled with water overnight but was not switched on
Obviously it sounds like the water inlet valve is leaking slightly. You have two possible solutions to try.
  1. turn the water off & remove the valve to check if there are foreign matter that may have gone past the filters keeping it slightly open hence the leak.
  2. You may have to replace.
Jun 03, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
We receive warm air, when turning on the ac
If set to position cold and hot air comes out, there is either a leak or there is a" two way valve" that hasent switched over. One needs an aircon tech check it out.(Two things to check though, look if radiator fan is working and if condenser is clean).Important factors..
Sep 14, 2009 | Heating & Cooling
AC trouble
You are low on freon, it needs to be topped up.
Jul 18, 2009 | 1998 GMC Jimmy
The ac is not cooling the air coming out in hot air I already tried to refill the freone and that didnt work is there something else I can do before taking it in the shop?
the aircon pump have a electromagnetic clutch.
test to see in clutch work.remove belt switch ac on and try to turn ac pump. it must not turn easy. wen ac of pully must turn free.
Jun 28, 2009 | 2002 Ford Expedition
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Heating & Cooling Logo
237 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
