Question about Nikon Speedlight SB-600 TTL Flash
Continous firing flash
How to continue firing flash because every time fire once have to wait 3-5 second ready to fire flash?
  • Mattivell Nov 16, 2008
    I have the same problem with my SB-600 where it takes a few seconds to flash which proves to be extremely annoying as I do a fair bit of event photography and if I am trying to capture a moment; it is gone by the time the flash/camera has fired.
  • 62 Answers
You have a bad cpu chip in this flash . You need to send it ijn the the manufacture at NIkon .
BERRIE SMITH CAMERA REPAIR
770-312-0719 / bbmw@bellsouth.net
Posted on Nov 28, 2008
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
Flash fires irregularly... good exposures, then suddenly 3 way under exposed/black then a good exposure, the a completely burnt out over-exposed shot! Completely irregular.
If you are referring to the internal flash I would say you are firing the camera faster then the flash can cycle. There is a green lightning bolt that will come on in the viewfinder when the flash has charged. If you fire the first one it may be a charged flash then again you may have popped the flash composed and tripped the shutter before the flash has had a chance to fully charge. You fire again depleting the charge some more and before it has a chance to recover you fire it again so the flash never has a chance to fully charge. You need to wait till the flash ready light come on in the viewfinder.
Dec 18, 2010 | Nikon D70s Digital Camera
My central heating unit is in the attic of my 2bd/2bth house. I don't know its age. It's a gas unit, but doesn't have a constant pilot flame. Rather, the pilot is ignited electronically. The problem is...
You don't mention make or model so here is my guess as to how to thinkout the trouble of what ever is in your attic.
For some reason, your heater is mis-firing. Normally, I would expect 3 to 5 such events at which time the heater goes out on safety. The heater knows it is on safety but you don't until it gets cold in your house. When you turn the power off, wait the 30 seconds, turn it back on, the heater no longer knows it is on safety (memory cleared) so it fires. Your heater continues to fire until ? at which time it starts counting again to 3 or some number. At the max mis-fire number - it goes out on safety again ... repeat - turn it off, wait 30 seconds, turn it back on - no memory and so forth.
Do you have a service contract or regular service man? Might be time to find one.
Thanks for your question at FixYa.com
Jan 05, 2010 | Heating & Cooling
99 cavalier theft light on continous
does it run 2 to 3 seconds? does the scurity light blinks? if yes leave the switch on after running 2-3 second wait till security light stops blinking then start if light still blinks you have wiring problem. if light just stay on you have spark and fuel check injactor pulse.always remember if you have good spark ,good fuel pressure and injector pulse car should start
Sep 15, 2009 | 1999 Chevrolet Cavalier
580EX speedlite not firing
Does the pilot lamp light up? If so can you fire it manually by pressing on it? If the batteries are low it may simply just be taking a while to charge, the camera will not wait for it to be ready to fire and it may seem to be not working. If your flash can be fired manually however, there may be a problem with the cameras shutter or the hotshoe. You can do a basic check by pressing the star button at the rear of the camera, you should get a pre-flash. If not, there is a problem with the cameras hotshoe which you will need addressed by a service centre. If you get a preflash you can next check the cameras shutter by setting the second curtain to sync with the flash. This can be done via the cameras "Custom Function" menu, c-Fn 15. Set the camera to TV mode and chose a 1 second exposure. Take a shot with the flash attached, if the shutter is working correctly, the flash should fire a pre-flash and then a main flash. If it doesnt, the switch inside the shutter is broken and the shutter needs to be replaced. This is a pretty labour intensive repair and you may consider an upgrade as more economical.
Apr 14, 2009 | Canon SPEEDLITE 580EX TTL Flash
Sunpack 555 inconsistantly fires with Pentax K20
Your strobe is faulty and needs repair at a trained service center. The actual culprit may be the voltage converter circuit that supplies the high voltage to the flash capacitor, or the voltage divider that drives the ready lamp and, at the same time, makes triggering possible.
Feb 16, 2009 | Sunpak Auto 555 TTL Flash
Flash takes too long
Its all relative. With most of these compact cameras, to conserve power, the camera does not always keep the flash ready to fire at any given second. Firing the flash uses a lot of juice, so if it was always at the ready, the battery life would be reduced to half or less, which would would cause more problems.
When you press the button the camera then tries to cycle up enough flash power that it thinks it will need to light the scene correctly. This will require less time if its in the day and longer if its dark.
Add more time if the battery life is low.
Once you fire the flash and exhaust all the reserve power from the buffer, the camera will need to recycle itself to garner enough power for another flash, this again adds time.
More expensive cameras have better power management and can cycle up faster.
Dec 16, 2008 | Kodak EasyShare C743 Digital Camera
Flash doesn't fire
Should fire from test button. If not flash tube is blown.
Jul 08, 2017 | Digital Concepts 952AF for Pentax Flash
Problem with AF-360FGZ Flash
Yes. The *istD shutter can only provide X-sync for electronic flash up to 1/150 sec. The *istDS reaches 1/180 sec. "High speed" electronic flash is done by strobing the flash repeatedly during the period that the shutter slit is traveling across the focal plane, at th expense of cutting power output quite a bit.
Sep 08, 2005 | Pentax AF-360 FGZ TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
