Question about HP Compaq Presario 2200 Notebook
HOW YOU TURN OFF THE STICKY KEY - HP Compaq Presario 2200 Notebook
Dell inspiron n4030 keyboard not working
Shapsog,
You may need to turn off the Filter Keys option. Follow the steps below to turn them off.
Go to
1. Control Panel
2. Ease Of Access Center
3. Make the keyboard easier to use
4. Uncheck the "Turn on Filter Keys" option
You also may need to Check to be sure you don't have Sticky Keys enabled.
BY PRESSING THE SHIFT KEY FIVE TIMES
Without pressing other keys, press the SHIFT key five times to enable Sticky Keys. A window will be displayed asking you if you wish to turn on Sticky Keys Clicking Yes will enable Sticky Keys or click No.
If none of these steps work you may need to replace the keyboard or plug in an external USB keyboard.
Thank You,
Dell-Jesse L
Dell Social Media and Coimmunities
Oct 19, 2015 | Dell Inspiron N4030 14 Inch Notebook...
Shift key is not working
You might consider using, at least tempory, a external usb keyboard with a touchpad, you can get get them at Wal-Mart for around $20.00
Otherwise consider taking it to a computer shop and have them test the keyboard and if need be order you a new one. If this computer is still under warranty then I would would talk to the support team that you purchase it from. Good Luck.
Mar 28, 2014 | Computers & Internet
Turning off my green keys on HP pavilion desktop keyboard?
How to turn off Sticky Keys: disable the Ease of Access feature
Tip: use the Windows Ease of Access Center
How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
How to turn off Sticky Keys in Windows 8
You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
If this does not help you. Let us know the below details to understand the issue bettery.
What is the OS?
What do you mean by hot keys? ex.......
Rgds,
Divya
Sep 02, 2012 | HP (395366-001) Keyboard
Sticky key korg M1
Sticky from what? A liquid Spill??
Turn the laptop off and keep hitting the key until it stops sticking.
May 11, 2012 | Computers & Internet
My laptop is entering more than one character at a time when typing in my password for example its adding additional letters how can i turn this off
seems like something is ring with the keyboard, try an external keyboard, if the issue is still the same this will be a windows issue, once in windows tap on the shift key 5 times this will either deactivate sticky keys or ask you to activate sticky keys.
If it is not a sticky key setting issue then the problem most likely will be Hardware, did any liquid spill on your keyboard previously causing the key to malfunction causing the key to type extra characters?
If none then possible this is a faulty keyboard on the machine.
Sep 10, 2011 | Computers & Internet
Sticky keys how do i fix it?
Hi Dgr Welcome to fix ya !
The sticky keys are part of Windows Ease of Access Center Accessibility program.
1. The easiest way to enable/disable the sticky keys is to press the "Shift " key five times. This will turn on/turn off the program.
2. The second way is to press the Windows logo key + U at the same time. This will open the Ease of Access Center. Then select the link that reads" Make the keyboard easier to use."
3. Under the section that reads, "Make it easier to type" you have the option to enable the Sticky Keys or a link to Set Up Sticky Keys. Select whether you want to set up the Sticky Keys or just enable them if you have previously set them up. If setting them up for the first time, remember to click "Apply" after making your selections.
Hope this helps. If you need further assistance, just leave a comment at the end of this solution and I'll be glad to help. Thanks for using Fix Ya.
Jul 10, 2011 | Computers & Internet
Im not sure what happened but a sticky key caption appeared on my screen and i just deleted but since then when i hit shift key to get symbols and the AT sign it wont work and its frustrating when trying...
You've turned on Windows' "sticky keys", one of the accessibility options. Pressing the Shift key 5 times in a row activates it. Sticky keys lets you type key combinations (Shift-x, Ctrl-Shift-x, Alt-x, etc.) one key at a time. It's for people who have trouble holding several keys down at once. Press the Shift key again 5 times to bring the sticky keys dialog box back and turn off the function. You can also disable it permanently in the Control Panel's accessibility settings program.
Jan 25, 2011 | Computers & Internet
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
I held down the 'shift' key too long and now the keyboard restricts the backspace key to one space and wil not alow me to type the same character twice. Se what i am talking about?
Sticky keys I hate that too
hit shift 5 times it will bring up a box
ok to keep sticky keys
cancel to turn off sticky keys
hit cancel.
Oct 27, 2009 | Gateway Profile 4 All In One (MPN...
I have a hp laptop model no dv 2046 tu...the problem i m facing is that my keyboard's ctrl key is stuck...whenever i press any key....a combination of that key wid ctrl is is taken...example....if i press...
This solution is for Windows XP.
If you see no physical sticking, then you may have "Sticky keys" on.
To look to see what your "Sticky Keys" Settings is at do the following:
In "Control Panel" double click "Accessibility Options"
A new window will pop up. The first tab is "Keyboard".
The first box at the top is "Sticky Keys" make sure that is unchecked.
"Sticky Keys" can be automatically turned on if you hold down certain keys for a predetermined length of time. Usually a box will pop up asking if you want to turn it on.
Thank you.
Please rate me.
Jan 27, 2009 | Computers & Internet
HP Compaq Presario 2200 Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
