Question about Teac Nostalgia SLD90 CD Boombox
Clock running slow
How can I adjust the clock - it loses approximately 1-2 minutes per day? Thanks!
0 characters
1 Points
How do you set the time on a JVC KDG210 radio?
Try the following:
  • Press and hold SEL (select) for just over two seconds until the display shows
  • "DEMO", "CLOCKH", "CLOCKM", etc.
  • Select "CLOCKH" with the '>' button, then adjust the hour needed with the dial surrounding the "SEL" button.
  • Select the "CLOCK M" in the exact same manner.
  • Finish by pressing the "SEL" button.
  • Lastly, the "DISP" button displays the time after cycling through.
Hope this was helpful. Thanks for visiting
Feb 02, 2011 | Boomboxes
1 Press STANDBY/ON to turn off the unit, if it is turned on.
The clock flashes on the display window.
2 Press and hold PROGRAM/CLOCK SET for more than 2 seconds.
The hour digits start flashing.
3 Press the CD forward or CD back button (track skip buttons) to adjust the hour, then press PROGRAM/CLOCK SET.
The minute digits start flashing.
4 Press CD forward or CD back button (track skip buttons) to adjust the minutes, then press PROGRAM/CLOCK SET.
I hope this helps.. !
If you need more info have a look here for the manual which is in pdf format:
The clock information is on page 10
JVC RC-EX25 manual
Oct 12, 2010 | JVC RC-EX25 Radio/Cassette/CD Boombox
Model rv-b99 loses presets and does not power off
whenever I run into a memory issue with a portible unit that uses a battery backup I have found battery corrotion on the battery cointacts! also remove the main power source the batteries the wall plug and let it set for several minutes and hit the power switch a few times then retry everything again
May 14, 2010 | JVC RV-B99GY Cassette Boombox
How do you set the clock on a JVC PC-X250 boom box?
Using trial and error, I set the time on my JVC PC-X250 boom box by:
1. Turn unit OFF.
2. Press and hold PROG/SET button until hour digits start flashing.
3. Use SEARCH DOWN and/or UP buttons to set correct hour (including AM/PM).
4. Press PROG/SET again until minutes digits start flashing.
5. Use SEARCH DOWN and/or UP buttons to set correct minutes.
6. Press PROG/SET again until time is not flashing.
Oct 22, 2009 | JVC PC-X250 Cassette/CD Boombox
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
ILive docking station not working properly
hello everyone with this problem I bought a use unit last sunday and it was working ok till next day then not sound not light , I try to push every botton and shut off and on but nothing , after many times I decide to open the boom box , and resoldering all the connections take like 1hour but now the unit works perfect the only thing is the blue light never came on , but cd works fine and radio also the dock for the ipod , is working fine
Aug 06, 2008 | Apple iLive IBCD3816DT Portable 2.1...
RCA,RP9328A,Audio System
I did the following to set the clock:
1. Press the Timer/Clock button until "CLOCK" shows, blinking, on the display.
2. Press Set/Demo. The hour indicator on the clock should start blinking.
3. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the hour.
4. Press Set/Demo. The minute indicator on the clock should start blinking.
5. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the minute.
6. Press Set/Demo twice. (Pressing once moves to the timer set mode.)
Feb 09, 2008 | Boomboxes
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
The hour digits start flashing on the
2 Press 4 or ¢ to adjust
The minute digits start flashing on the
3 Press 4 or ¢ to adjust
the minute, then press
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
You're welcome in advance.
This particular unit was advertised to be unbreakable when dropped due to its shock absorbers; therefore dropping it will fix it.
Oct 24, 2007 | Bosch PB10-CD Radio/CD Boombox
Teac Nostalgia SLD90 CD Boombox Logo
19 people viewed this question
Top Teac Boomboxes Experts
Jonathon summesfield
Are you a Teac Boombox Expert? Answer questions, earn points and help others
