Question about Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator
NO OUTLET POWER
NO GENERATE AC
  • 4 Answers
There can be several causes for this symptom. Does the outlet have a breaker or "switch" that is tripped? If this is a GFI (ground fault circuit interrupter) outlet, first disconnect any cord or equipment plugged into the outlet, then press the "reset" button in the middle of the receptacle. The GFI's should not/will not reset with anything plugged in. (If they are working correctly.) More specific information needed if this does not take care of the problem. There are numerous other things which could be causing this problem, loose conections, bad generator, broken or damaged wires on the electrical system, inverter problems, etc. Refer to your owners manual if at all possible, take a look here at this link if you don't have a copy.<<< http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DG6000&selectedType=6326# >>>>
Posted on Feb 22, 2012
How to increase the output voltage
Measure the Generator after 10 minutes the first measure but not only to one power outlet with doing a measure with a multimeter its not done so because the generator is fully unloaded then you will see 105 vac
Measure on one outlet and use a paint stipper a 2000 watt type and measure at the same time on the second power outlet with a multimeter on AC you should get more volts out to measure instead of 105 volts then you hear that its generate power and blow more smoke you will be seen a 115 or 120 volts if you increase this generator its possible you get if you are increase the idle power to 120 volt can create an over loading of 200 volt or more over the outlets that can give damage if it the stator electric field generate power outside its level it can blow up your expensive tools and in a short time you think there is not enough power on my tools anymore then your armatures are become bad and the tools are hot in a short time warmt dissipation has blow up armature and nothing smels hot but the tools are blowing up. and you see nothing inside because the tools will not are getting black burned and hot but the to high magnetic pulse burns the weak points inside the armature in a fraction of time.
Beware of that the adjusting is normally doing with a tacho meter and a suggestion of about 3000rpm and not more of the stator what its max depend on model . but adjust by the load power of a working paint stripper it can have enough if you adjust 120 volt by load.
Mar 06, 2016 | Electrical Supplies
Pl provide security code of ford 6n29-18C815-AC CD player
Post the M number and i will generate a code for you
Dec 07, 2014 | Cars & Trucks
Presently new led models particularly sony tvs manufactured with adapter type so for this any stabilizer required???
The power supplied with the TV is regulated. There are no high voltages in LED TV's. LCD TV's generate about 200Volts to strike the back light and then they run at around 90Volts.
Oct 31, 2014 | Computers & Internet
What is the resistance of the 1bank 02 sensor on a 04 4runner
O2 sensors don't use resistance to test.
They generate ac voltage when in use. The heater side of the sensor can have resistance but generally you would check for power in and ground out.
Sep 01, 2013 | 2004 Toyota 4Runner
The genarator if there is one regular? gives no pover to the battery
it generates less than 9 amps. they don't need a regulator to control voltage. some generate ac and dc current... for charging the battery is dc and running the headlights is ac
Aug 20, 2013 | Briggs & Stratton Garden
Dell latitude D505 battery not charging
Take Dell latitude D505 battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps
Mar 31, 2013 | Dell Latitude D505 Notebook
Tha half moon light blinks green,standby light also blinks with battery light orange light when charger is connected to my thinkpad t61p ,no booting
Step 1:
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Feb 17, 2013 | Lenovo ThinkPad T61p 15 inch widescreen...
Windows 7 battery not charching
Im assuming its a laptop ?
Jan 28, 2013 | Microsoft Windows 7 Home Premium 32Bit...
Battery not charging
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.Remove the Battery Sometimes it's as simple as a seated battery.
hope this helps
Jan 25, 2013 | HP Computers & Internet
My laptop battery willnot charge
For this kind of issue, you may try the following troubleshooting steps:
Take your laptop battery out, plug in the charger and see if the laptop works.
hope this helps
Jan 08, 2013 | Advent Computers & Internet
Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator Logo
290 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
poellot86
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
