Question about BroilKing 55384 (LP)
Ignition button no response
Is there a battery that needs replacing?
Despite having replaced the battery the engine of my SH300i does not start.There is no response at all from the starter. How can I solve the problem?
Hi, Pierre and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Scooter won turn over
Scooter won start
Startup Troubleshooting Starting Your Scooter 1 7
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/32KTWB12_LT.pdf
Sep 22, 2016 | 2011 Honda SH300i
How do I remove the key lock cylinder on a 2004 Grand Prix
NO MENTION OF SIR PRECAUTIONS FOR THIS PROCEDURE.
UUSE THIS GUIDE AT YOUR OWN RISK!
I do not assume any responsibility.
tiftogif?pic=910510
UDEDisconnect the battery ground cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
  • Use a plastic trim tool to remove the ignition switch bezel.
  • tiftogif?pic=519619
  • Remove the instrument panel (I/P) accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory .
  • Remove the left I/P insulator. Refer to Closeout/Insulator Panel Replacement - Left .
  • Remove the opening filler panel from the I/P steering column. Refer to Steering Column Filler Replacement .
  • Remove the I/P driver knee bolster. Refer to Knee Bolster Replacement - Left .
  • Remove the ignition switch bolts.
  • tiftogif?pic=929187
  • Lower the ignition switch away from the I/P trim pad.
  • Insert the key into the ignition lock cylinder. Turn the key to the ON/RUN position.
  • tiftogif?pic=928654
  • Depress and hold the detent on the bottom of the ignition switch in order to release the ignition lock cylinder. Remove the ignition lock cylinder with the key.
  • Remove the key from the lock cylinder.
  • tiftogif?pic=639144
  • Disengage the theft deterrent reader/exciter module retainers (1,2).
  • Remove the theft deterrent reader/exciter module (3) from the lock cylinder housing.
  • Remove the lock cylinder.
  • If the cylinder does not rotate, follow the procedure in the ignition switch replacement. Refer to Ignition Switch Replacement .
  • Note: If you need any of the procedures expanded, let me know.
  • No mention of SIR precautions made for this procedure.
  • USE THIS GUIDE AT YOUR ON RISK!
  • I do not assume any responsibility.
    USE
    USE THIS GUIDE
  • Jun 29, 2014 | Cars & Trucks
    No response to Start button, battery is good, no signal lights
    Hi Anonymous, check fuses and circuit breakers, check countinuity at start button and ignition switch. Good luck
    Jan 02, 2014 | Harley Davidson FLSTC Heritage Softail...
    Prestige APS787C wont start car
    Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
    Feb 11, 2013 | Prestige Remote Start
    Ignition button- no response
    Unscrew the ignitor cap there should be a double A battery there, if not you can get ignitors at any barbeque store, Ace hardware etc.
    Feb 22, 2012 | Crown Verity Broil King 40 Propane Grill
    Car OK in morning. Went to use in afternoon would not start. Looked closer and ignition on, headlights work but no response from auto button start. Also car will no lock. If door left open it chimes,
    put the battery on charge overnight and then try to start tomorrow ,i think it just ahs a flat battery and nothing more is wrong ,use a trickle charger and leave it on for a least 12 hours
    Jan 27, 2011 | 2009 Ford Focus
    No electrical power to my bike.
    Try another Ignition switch to see if any power is available. Unfortunately this is a problem that can't be solved here, wiring is something that needs to be diagnosed by someone working on the bike.
    Mar 19, 2010 | 2000 Suzuki VZ 800 Marauder
    SAME PROBLEM, replaced battery in both fobs....
    the keys needs to be initialised. put key in door lock or ignition barrel and press/hold the remote open button until led flashes on dash, release button and rremove key from lock, remote should now work
    Aug 30, 2009 | 1999 Porsche Boxster
    No response from ignition dead
    check and replace if worn out ignition wire ,ignition solinoid and the wires connected to the ignition switch up to the battery.
    Jul 27, 2009 | Orion Vehicle Parts & Accessories
    BroilKing 55384 (LP) Logo
    27 people viewed this question
    Top BroilKing Grilling Experts
    paulcarew
    Gary Kenady
    Gary Kenady
    Dan Webster
    Dan Webster
    Are you a BroilKing Grilling Expert? Answer questions, earn points and help others
