Saws Logo
A
Anonymous Posted on Feb 22, 2012
How do you change the teeth on a Tanguay Slasher circular saw?
The teeth on the saw blade need to be changed. How is this done?
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Oct 27, 2008
SOURCE: Older Porter cable circular saw blade removal
Clamp a pair of vise-grips onto the blade to act as a blade-lock to stop rotation of the blade.
Anonymous
  • 15 Answers
  • Posted on Nov 18, 2008
SOURCE: How to keep the blade guard off the Circular saw blade when in use?
What is (B and Q) stand for ? This is a circular saw or a table saw, or a miter/chop saw?
muttandjeff
Allen Neal
  • 359 Answers
  • Posted on Jan 02, 2009
SOURCE: how do i change the blade on craftsman circular saw?
some saws don't have a blade brake , i always take a pair of vise grips and adjust to grip blade tightly and hold or bind against housing then remove bolts works well for me
Anonymous
  • 239 Answers
  • Posted on Feb 07, 2009
SOURCE: changed delta saw blade
it turns the other way, to the right!
Fred Yearian
  • 5603 Answers
  • Posted on Sep 28, 2009
SOURCE: ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Testimonial: "Thanks; that's the advice I got when I tracked down the number to call Ryobi. However, it doesn't seem to be working. Now sure what is wrong :("
How to change blade on skilsaw 5380
on a circular saw
pull the power lead from the plug
using a screw driver , place the blade between the teeth and turn until the screw driver is jammed under the plate
use a ring spanner and undo the nut that holds the blade on
pull the blade out and fit the new blade with the direction arrow in the right direction
replace the plate and the bolt do the bolt up tight
rotation will tighten it up
some blades have a hole in the blade in which to insert the screw driver to hold the blade , or a lock lever behind the cover to hold the armature shaft while changing the blade
Dec 21, 2016 • Saws
Need to see how to change a blade please
make sure the saw is disconnected from the power point
place a screw driver in the teeth of the saw and turn it back until it locks against the base plate ( some blades have a hole in the blade through which a pin can be placed )
undo the spindle nut
replace the blade and do the nut up tight
Jan 09, 2016 • Saws
How to remove arbor bolt to change blade
Best thing to do is to just rest the blade teeth against a peice of scrap wood, and use the allen key/spanner to undo the bolt. As the bolt undoes in the direction of the cut, the blade teeth should dig in and stop it turning. If the blade lock isn't working anymore, it could mean that it has broken inside, so be careful, incase there is a bit of loose metal in the gearbox, it will be quite catastrophic if it gets caught in the gears.
How many teeth blade can i put on a circular saw
You can put any blade in your saw as long as the diameter of the blade isn't bigger than your saw is made for and the hole in the blade fits the arbor properly. The number of teeth only affects the speed of cut and how smooth the cut is. Fewer teeth cut faster but leave a rougher cut edge. More teeth cut slower but leave a cleaner cut surface and edge.
Jun 14, 2012 • Saws
MAKITA DROPSAW MODEL 2400B HOW DO I CHANGE THE BLADE
There is a push-in lever located between the handle and saw blade.
Push in lever and rotate blade until blade locks.
Once blade is locked, loosen nut located in center of blade.'
Before removing blade, notice direction of teeth.
Install new blade with teeth going same direction.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
3helpful
2answers
How do I change the saw blade on my 2 hp 7 1/4 saw?
If the saw doesn't have a locking mechanism for changing the blade then you will have to jam a piece of wood in the teeth of the blade so that it cannot turn. Remember safety first. Ensure the saw is unplugged and wear leather gloves when changing the blade. Use a socket or wrench to loosen the nut that holds the blade on and remove the blade. Use the reverse procedure to tighten the blade.
2helpful
Not cutting in straight line
Normally blade overheating. Improper blade or too few teeth for material, teeth not sharp and/or offset enough for proper width of cut. Teeth must cut wider than blade. Inexpensive blades tend to do this quickly. Other possibility: Bad bearing, check for play with saw unplugged. Blade should have little wobble. Other possibility: Saw body cracked/damaged(allowing shaft to skew) or very cheap saw unable to handle material
Sep 25, 2009 • Saws
McKeller circular saw - how do I change the blade. It's not as simple as others.
place a large screwdriver or small pry bar perpendicular to the blade,between the teeth & against the bottom of the plate to hold the blade & motor so you can remove the bolt.
Sep 21, 2009 • Saws
Finding the lock button..changing a circular saw blade? "skill saw brand,usa" cannot seem to find it anywhere
older model of circular saw dont have a spindle lock.wedge the blade on a bench vise & make sure ur not clamping the teeth of the blade & then turn the blade screw clock wise.
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
