Reset to factory settings for sony pcg 2j3l
Hd virus
5 Suggested Answers
tat4u
  • 520 Answers
SOURCE: PCG-9G1L SONY
not too sure what you mean here.you can reset bios to default or can set bios to factory reset.to set default ...when you turn on pc ,message at bottom left hand screen indicates which key to press to enter setup(bios setup) note...its very brief;mines f 10 for instance.at startup press this key and select load default then select save settings and exit;then ur pc restarts with default settings.
To reset bios to factory requires disassembly.
you locate rtc and remove battery(looks like large watch battery)for 5 minutes then replace,reassemble and restart pc.you dont need to know what rtc means(real time clock)or what it looks like cos the battery is right next to it.
Posted on Mar 04, 2008
BoxenRyan
  • 31 Answers
SOURCE: sony vaio model PCG-E91L: want to restore it to
Hold Shft + F10, or Alt + F10 to restart Recovery Setup on Vaio.
Sincerely,
Ryan Deschaine
Systems Administrator
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.254.0064
Mobile number: 262.834-5844
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Posted on Sep 23, 2009
tgvern
  • 281 Answers
SOURCE: How do you replace the DVD/CD Player in the Sony Vaio PCG-2J3L?
It sounds like the bezel (the trim piece attached to the front of the drive) is what came off. You can usually still get it to open in this condition, but you have to get creative a bit.
typically the eject button is a physical button, but it depresses a small electronic button when you press it. This should get it to open. Otherwise, you can right-click the drive in my computer and select "eject". If that doesn't work, use the paper-clip method. Look for a small hole (on the bezel) which lines up with the emergency eject button on the drive. Straighten a paper clip and insert it at this point, which should eject the drive.
Then I would turn off the machine, (leaving the drive open) carefully turn it over. Look for a locking (retaining) screw on the underside of the laptop. On many models the screw is accessible without removing anything else, but I have seen where the screw is hidden under other components; proceed at your own risk here.
Once you have found the screw and removed it, that should be all that is holding it in. You can tug gently on the drive and it should slide right out.
From there, find the replacement model (I like ebay quite a bit for this type of part, since it will be much cheaper. Note the Model # which is usually on top of the drive on a label. It will make finding a replacement much easier than trying to shop by your laptop model #.
The key here is getting the correct type of data connection. As long as the bezel fits your computer, and unit will work (make sure you get the right kind of drive: DVD-R, DVD-ROM, CD-RW, CD-R, or some type of combo drive). While you can also find these parts on the internet, watch for some type of warranty on the product in case it fails to work. Many reputable sellers will have at least a 30 day warranty, which gives you time to test the product.
Once you have your replacement, examine it and make sure any trim pieces line up (you can also remove them from your old one if needed), then slide it into the slot, reinsert your locking screw, and you should be ready to test it.
I would test all functions of the unit right away: if it's a recorder, test burning a cd or dvd, play a dvd movie etc. to ensure everything works. I have seen a DVD-R drive that works for everything except recording DVD's (will play DVD's and CD's just fine, but not record).
Good luck and thanks for your question.
Vern
Posted on Dec 05, 2011
StuartB
  • 807 Answers
SOURCE: sony pcg-fxa63
You can buy recovery disks, here's just one place.
http://recovery-disks.com/sony-vaio-pcg-fxa63.html
$30.
Posted on Feb 12, 2012
How do I factory reset a Sony Vaio PCG-792L aptop with Ubuntu?
Download the version of Ubuntu you require, burn it to a disc. Start the Sony up, booting from the DVD drive and install a fresh OS.
Dec 29, 2015 | Sony Computers & Internet
I Have a Sony Vaio PC all in one Model No. PCG - 2J3L When you turn it on the screen will come on for 3 seconds and go black but you can hold a flash light to the screen and see it is still working or
A couple of thing will cause this, The backlighting is going out due to a tiny switch, that controls the light when you open and close the lid. It's located near the hinges, it can get stuck due to dust or a misaligned hinge. Take a look at this: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Dec 04, 2012 | Computers & Internet
I have a Sony Vaio PCG-2J3L and when the lighting for the screen is on bright the screen will stay lite for a couple of seconds and then go black but you can take a flash light and turn it on the scre
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sony vaio pcg-2j3l desktop will not power on
Just to clarify, the box (power brick) in the middle of the power cord is the power supply. With that said, there is a light on the box (may be green, blue, or some other color). Does it come on when you plug it in (assuming that the wall outlet or serge protector has power)? If it doesn't then the power cable needs to be replaced. If it does then there is something wrong with either the cable going between the box and the computer, the power connector, or the connector on the computer.
Oct 19, 2012 | Computers & Internet
No video from model PCG-2J3L
first check the smps is working by shorting the green and black pin then check the cpu fan is working and if working remove the memory from the memory slot and clean the surface and insert it into socket and see wether the couputer boots if still not working remove the motherboard clean the surface and add some thermal paste and fix the heatsink tightly to the processor
Oct 01, 2011 | Sony Computers & Internet
Forgot bios password sony vaio model PCG-3A4L
Most motherboards are made with a reset switch. It is a line of three pins, with a jumper over two of them. To reset the bios (completely... everything back to factory settings) you move the jumper onto the other end of this line. Then boot the system up, turn it off again, put the jumper back into its original position and there will be no bios password.
Mar 13, 2011 | Sony VAIO PCG-3A4L Laptop Charger...
Sony Vaio PCG-TR3A, Blue Screen states cannot find operating syst
There should be a factory image on the HD when you try restarting it. Hold down the F8 key or F10 key while its rebooting this should start the recovery process you shouldnt need a windows disk.
Dec 04, 2008 | Sony VAIO PCG-TR3AP1 Notebook
PCG-9G1L SONY
Mar 04, 2008 | Sony VAIO FXA63 Notebook
Computers & Internet Logo
397 people viewed this question
David Payne
David Payne
