Hi all, My monitor does not get on.The LED doesn't glow. I checked the cable & it is in working condition. Before this the monitor used to show me the menu screen continously. Even if exit button on monitor is pressed it did not exit from menu screen. After that it went dead. I think there is possibility of loose connection somewhere. Can somebody tell me how to open the monitor cover. I'm struggling with it. Pictures will be very much helpful. Thanks in advance.
SOURCE: Problem with Control Panel
It sounds like theres a front panel button that has become intermittant and making contact all by itself. Sometimes when you clean the screen, the cleaner will drip down between the crt face aqnd the cabinet and make the switch in front go bad. Im not sure if this is the case in your problem but its a start. If you didnt spill anything or drip anything into the front panel then your maicroprocessor could be causeing the problem, or the 5 volts that feed the micro could be noisy ie, bad filter capacitor in the power supply. Now as im sure your aware of the hi voltage inside these sets? Its best if you dont have the training to get a pro to assist you as this hi voltage can hang around inside the set even if its unplugged. Good Luck
Posted on Jul 03, 2006
SOURCE: problem with samtron 56v 15" monitor
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
Posted on May 12, 2007
SOURCE: Open cover of Samsung Samtron monitor
remove two screws on lowerback of the monitor. Loosen the case at the botton and on the top. Two holes will appear on the top. With thin screwdriver push down inserting the screwdriver into this notch.This will release the case. Tks
Posted on Nov 13, 2007
SOURCE: No video output
Add a 50 ohm between pin 5 and 6 of the NT68F63LG IC.
Go to this link to learn the details. http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&sa=X&oi=translate&resnum=3&ct=result&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I tried this fix on my monitor and it works now.
Posted on Aug 25, 2008
SOURCE: Samsung 931 B - Dual monitor setup. one monitor
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once inside there will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! The other screen/monitor blinking(surging) is prob caused by the other monitors faillure and should stop when you replace/fix the broken monitor.
Posted on Feb 01, 2010
Testimonial: "exceptional answer and very detailed. I already got it fixed professionally but if i read this first - i could have done it myself and saved $50"
Jul 04, 2011 | Computers & Internet
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
Jul 24, 2010 | Sony CPD G420 19" CRT Monitor
Mar 14, 2010 | LG 500LC Monitor
Mar 04, 2010 | Computers & Internet
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
Nov 19, 2009 | Intel Motherboard
Mar 27, 2009 | Aspire Red X-Cruiser Mid Tower ATX Case...
Dec 07, 2007 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
32 people viewed this question
