Question about Delfield Freezer 6151XLSR Stainless steel
Our freezer is stuck in defrost mode, why? - Delfield Freezer 6151XLSR Stainless steel
How tofind out if your chest freezer is stuck onn defrost mode
If its in defrost mode it will get warm and the frost will melt. People usually just unplug them. Tge compressor usually has a switch or temp knob. It may be in back by the compressor underneaith. There would be an indicator as to the temp.setting on it. It may not have one at all and may have another issue.
Jun 23, 2014 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Why a Frigidaire freezer seems to be stuck in defrost model number LFFU17F5HWC
Good Morning Friend,
I understand that your Frigidaire freezer, model# LFFU17F5HWC, seems to be stuck in a defrost mode. Your freezer is supposed to automatically defrost for 30 minutes after every 12 hours of compressor run time. I suggest resetting your appliance, be either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Restore power and watch to see if it is still stuck in defrost mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hoshizaki freezer stuck in defrost
most likely a fan not running or a bad defrost timmer. open door, press in and door switches and Feel or listen for a fan.. it is normal for ice to start to build on evaperator, this must be melted by a electric heating element when in its defrost mode..
Feb 01, 2014 | Hoshizaki Freezers
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 | Freezers
The freezer keeps defrosting and not keeping food frozen
I would check your defrost timer to see if it is rotating. It may be stuck in defrost mode. you can check this by manually rotating the timer dial CCW yourself. This will be located in the front bottom left had corner behind the vent panel.
Jul 17, 2011 | True 49 cu. ft. / 1388 liter Commercial...
Frost on wall
Hi, The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Take care
Jul 17, 2010 | Woods Freezers
Ice builds up in the freezer
Take care
Jul 17, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
Stuck in defrost mode - control board thinks it's in defrost mode. Is there a way to reset the control?
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
go to this web site for your ops manual. It has details on the timer and some trouble shooting. Try this first. If it does not help. let me know and we can go alittle deeper.
Good Luck
Jun 02, 2010 | True 23 cu. ft. / 651 liter Commercial...
Small chest freezer, running but not freezing, cold inside, everything defrosted
the freezer has a defrost timer and relay. if either is bad, it may get stuck in defrost mode(depending on what position the switch failed in). The fan will run constantly if this is the case. You may choose to follow the wiring diagram on the back of the service panel or hire a technician. If you do it yourself, unplug the unit for your safety
Nov 19, 2009 | Freezers
Freezer does not work
The unit may be stuck in a defrost mode.Check the timer.Turn the knob to take it out of defrost.The unit will start up when this is done and the defrost timer is the culprit.
Nov 17, 2007 | Frigidaire 12 cu. ft. / 340 liter Upright...
Delfield Freezer 6151XLSR Stainless steel Logo
52 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
