Question about Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER
Need replacement parts
Tub and shower faucet #4051850
3 Suggested Answers
  • 15 Answers
SOURCE: Installed a new oak brook collection tub and
Most all shower valve's these days have anti-scald protection. There are 2 ways that this protection is accomplished; temperature control device or a pressure balance device.
If your's has a pressure balance device, both cold and hot water lines that supply your shower valve must be fully opened. If you only turned on one, water will not flow from the shower valve.
If both hot and cold supplies are fully opened and you soldered copper pipe to the shower valve, it is possible that excess soldered is was sucked into the valve and could be obstructing the valve's outlet.
Posted on Jan 25, 2010
packrat1948
  • 528 Answers
SOURCE: what size screw goes in the tub and shower chrome
Well Ace has these faucet made for them buy numerous manufactures and knowing which company made this one it hard to say. I would go to Ace and have them investigate this for you. Sorry but there is just to many variables here to be able to give a defiant answer to this question.
Posted on Feb 06, 2011
My american standard shower is sending water from the shower when using the tub faucet
Probably a defective, corroded or half stuck diverter. This is the part that diverts the water either to the tub or shower. Disassemble, inspect, repair or replace.
Dec 04, 2014 | American Standard Plumbing
We have a new shower. Water comes out of shower head and tub faucet together. What do I need to do?
its because that model usually when u pull for the shower is not properly connected. You will have to remove handle and coverplate, then shine flashlight down to see what is happening when pulling rod on tub spout for shower. Usually its broken or bent and just needs new one installed. It cost me 2 buck for new shower rod. Directions u can get free from Moen with free lifetime parts.
Oct 06, 2010 | Moen & One Handle Tub & Shower Faucet
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
& Replacement Cartridge : tub faucet leaks when shower is on...
Sounds like a bad diverter. Depending on what faucet you have some are on the tub spout and some are built on the valve. Both types can be repaired or replaced. I hope this helps.
May 18, 2010 | Moen & Replacement Cartridge
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
All in one tub and shower has a leaking tub faucet, how do i take the whole all in one tub and shoer out, and how do i fix the faucet to the tub then put shower and tub back in(all in one piece).
When I went to take mine out I had to cut it in half. Before doing anything drastic are you sure there's no way you can excess the plumbing from the other side of the wall? Its a lot easier to patch drywall than pull a tub. The faucet and pipes should be attached to the studs in the wall and not really attached to your tub. I don't really know what part of your faucet is leaking.. Some parts you should be able to excess from the front without pulling your tub. If its from the down spout you could probably loosen a screw or allen head that's on the bottom pull it off replace it or replace the O'ring inside. I hope I have help out.
Mar 04, 2010 | Moen & One Handle Tub & Shower Faucet
Leaky Faucet
You likely need to replace the Moen cartridge. There are clear instructions on how to proceed that come with the new cartridge.
Mar 14, 2009 | Moen & One Handle Tub & Shower Faucet
Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER Logo
65 people viewed this question
Top Ace Hardware Home Experts
guitar zan
Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
