Question about Samsung SyncMaster 943bw Monitor
Desktop has roated 90 degrees - Samsung SyncMaster 943bw Monitor
  • Ian Matthews Feb 22, 2012
    The desktop has rotated clockwise 90 degrees. How do we get it back?
    Found it, ALT Ctrl ARROW KEY
    What a pointless feature
    Scholar:
  • 54 Answers
Right-click on the desk top and look for items related to video. There may be two choices; if so explore them both looking for the words "90" "orientation" or "rotate."
Sometimes the short-cut "CTRL-ALT-UpArrow" works, but this depends on your software setup. (If you want to try this, press all three buttons at once).
Please post if this helps you!
Posted on Feb 22, 2012
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
Feb 26, 2015 | Opel Corsa Cars & Trucks
Cylinder head torque specs for opel corsa 8valve 1.4l 2005 model
Corsa 1.4I Engine code Z14XE 2000-2004
Bolts must be renewed
stage 1. 25Nm
stage 2, + 90 degrees
stage 3. + 90 degrees
stage 4. +90 degrees
stage 5. + 45 degrees
Sequence
10 6 2 3 7
9 5 1 4 8
bolts 7 & 8 are nearest to the flywheel side of the engine
Engine code C14NZ 1993-1998
Stage 1. 25Nm
stage 2. + 60 degrees
stage 3. +60 degrees
stage 4. + 60 degrees
Sequence as above.
stage 1. 25Nm
Sequence
10 6 2 3 7
9 5 1 4 8
Stage 1. 25Nm
Sequence as above. <br />Corsa 1.4I Engine code Z14XE <b>2000-2004</b><br />Bolts must be renewed<br />stage 1. 25Nm<br />stage 2, + 90 degrees<br />stage 3. + 90 degrees<br />stage 4. +90 degrees<br />stage 5. + 45 degrees<br />Sequence<br />10 6 2 3 7<br />9 5 1 4 8<br />bolts 7 & 8 are nearest to the flywheel side of the engine<br />Engine code C14NZ <b>1993-1998</b><br />Stage 1. 25Nm<br />stage 2. + 60 degrees<br />stage 3. +60 degrees<br />stage 4. + 60 degrees<br />Sequence as above.
Jan 09, 2013 | Opel Corsa Cars & Trucks
Picture is 90 degrees out i.e. portrait not landscape. Have had to stand screen on its side. How do I correct this please?
If you are running Vista or XP, pressing Ctrl+Alt+(arrow key) roates the screen. Play about with different arrow keys until you find the one that gets the screen back to normal.
In windows 7, go to the control panel > Appearance and Themes > Display, and select "Change display settings". Under "orientation", choose "landscape", and you should be back to normal.
Jun 02, 2011 | Computers & Internet
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
My screen is upside down and my mouse right and left side are reversed, how can I change it back?
On my shuttle, there is a combination of button to turn the screen 90 degrees to the left or right. Something Like CTRL + ALT + Up Arrow or CTRL + SHIFT + arrow or ALT + SHIFT + Arrow , to rotate to different angle , also there are Viewing options in your display drivers. In the ATI control panel, there is a tab rotation to rotate the desktop 90 degrees to the right or left or 180 °
Try this.
Oct 12, 2009 | Dell Optiplex 755 Ultra Small Form Factor...
I need the head bolt torque settings can anyone help
2.4L and 2.7L is:
Step 1- 29 ft.lbs.
Step 2- 90 degree turn
Step 3- 90 degree turn
3.4L is:
Step 1- 27 ft.lbs.
Step 2- 33 ft.lbs.
Step 4- 90 degree turn
4.5L is:
Step 1- 27 ft.lbs.
Oct 12, 2009 | 1996 Toyota 4Runner
Desktop is turned 90 degrees. How do I get it back where it belongs
I love this one so many caught and so easy to fix!
R click on desktop go to Properties select ROTATE and take it to 90 degrees... enjoy!
Please rate our helop to keep the free service online
Aug 30, 2009 | Computers & Internet
Rotation of desktop
Flipped monitor display in Windows. Third-party software utilities such as the NVIDIA Settings have the ability to flip or rotate a monitor's display 0, 90, 180, and/or 270 degrees
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
SCREEN TURNED TO LEFT WHEN I HIT KEYBOARD WITH BOOK COVER
1. If you right click on the desktop and look at graphics properties, or something similar to that, then you should get a menu for your display adapter control panel. Usually the screen rotation is right there. Sometimes it's as easy as a CTRL + arrow key combination, but I'd rather see you adjust it from a menu.
2. Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees (If that doesn’t work, try Ctrl-Shift-R)
3. If you have the intel video chipset, I believe pressing CTRL+ALT+ one of the arrow keys should fix your problem.
I think it was ctrl+alt+right, but if that doesn't work, try the other three arrow keys.
However, if that doesn't work (especially if you do not have intel video), then right click on your desktop, go to properties, and go to the advanced tab. There you should find some setting that will allow you to reverse the rotation.
Dec 06, 2007 | Logitech Cordless Desktop EX110
Samsung SyncMaster 943bw Monitor Logo
93 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
