Maytag top load HE washer model MVWC400XW0 not spinning after rinse, but pumps and spins fine on spin and rinse cycle.
I have a Maytag top load HE washer model MVWC400XW0 which is not agitationg on first rinse, then not spinning on final rinse to complete wash cycle. You manually have to turn the selector switch to rinse and spin cycle to get washer to finish cycle. Spins and drains well in this mode. Hoses not clogged, pump operates fine, but runs for nearly ten minutes after rinse cycle starts the first time, the washer filled with cold rinse water, and sat w/o lid locked or any agitation for ten minutes, finally just started pumpimng water back out, then stopped, pumped again w/o pushing any additonal water out. Finally topped pumping and started filling cold water for second rinse. Never began spin cycle to complete. Is this a common problem among these machines? What are other typical issues to look for w/o cracking unit open and voiding warranty?g details will get you a faster solution from experts
2 Suggested Answers
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
Kenmore he21 washer fill agitates drains but will not spin
Hello;
My name is Peter. I am a retired field service technician.
The model number you gave HE21 comes up as a Maytag hot water tank.
Open the front door of you unit. The model number should be at the top on a tag.
Repost your question with this model number.
Nov 10, 2014 | Washing Machines
My maytag top load washer model #sav2555aww spins but not fast... I replaced the belt and that helped but still not like it did before.. Everything else works fine, any suggestions?
some of these machines have a timer conflict between rinse [ spin pulse ] and full spin at end of wash cycle the timer contacts remain in the pulse cycle the switching assembley may need replacing
Mar 05, 2011 | Maytag SAV2555A Top Load Washer
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
Maytag top loading washer 1994 does not spin during rinse cycle
The problem will be the spinning coil is cut off or short circuited kindly replace the motor and check it
May 17, 2010 | Washing Machines
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer
Start by checking the belt by tilting the machine back and examining for wear, glazing and cracks, next pull the belt to make sure everything turns. Post back if this looks fine.
Jul 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Top load washer
I am having this same issue, has anyone found the solution to this issue?
Oct 14, 2007 | Maytag PAV3240A Top Load Washer
Washing Machines Logo
152 people viewed this question
Top Washing Machines Experts
