FixYa.com
Tags:
Kenmore 22422 Top Load Washer
Kenmore top loader washer noisey agitator
posted by STAYHAY on Aug 28, 2006
This washer is makeing noises like you would nt belive.On spin cycle,it sounds like a slipping transmission .Then it started a ratcheting noise when agitating and wont agitate correctly. Unit just spins around, not back and and forth like it used to? what would be the first suspect for some thing like this ? thanks for any help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 09, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
agitator does not work
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 12, 2007
FixYa! (100)
The dog
Rank:Guru Guru
Rating: 86%, 204 votes
Sounds like a bad gearcase.There is a nylon gear inside that if it is worn out it will make a ratcheting noise as you describe. It will also cause it to spin and agitate at the same time. There is a 5 year warrenty on the gearcase. you pay labor only.
Provided by KENMORE STAFF
Solution #3
posted on Jan 12, 2008
FixYa! (100)
super tech
STAFF
Rank:Guru Guru
Rating: 87%, 120 votes
it sounds like the gear dogs in the agitator. pop he top of agitator and check. its a easy repair.
Solution #4
posted on Jan 28, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
may be a plastic piece that involves the gears, it breaks causing the same problem you descibe that i have had twice, its only 3-4 bucks if you take the washer in and service it
Solution #5
posted on Mar 03, 2008
Not Rated (0)
fidldad1
Rank:Guru Guru
Rating: 87%, 79 votes
the gear case bad if it spining makeing a loud noise and makeing a bad ratching noise in spin cycle
Can you Help with these Washing Machines problems?
Kenmore 70 series washer
Replaced timer, but still will... Answer This...
Need help fast w/ older...
We have a nearly 40 year old... Answer This...
Modle 80 washer.
My washer has just started to... Answer This...
Washer virbrates but is level
Washer vibrates so bad the... Answer This...
I DONT HAVE A CATALOG
i cant use perfect.really i... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
