Question about Kenmore Washing Machines
Kenmore Elite Oasis 20992 top load washer - Kenmore Washing Machines
  • 1028 Answers
SOURCE: need diagnostic test for Kenmore
pick any button but power or pause (spin works ok) pres and hold 3 sec release 3 sec hold 3 sec release 3 sec hold 3 sec this will put intio diagnostics usually if a fault code is stored this will show first press same button to step through post fault code if any asap and will try to help may to try several times to get into diagnostics
Posted on Jun 22, 2008
SOURCE: for the kenmore elite oasis
We jamed a straw in the door lock so the sensor thinks there is something in there
Posted on Jul 03, 2008
blueextc3221
  • 15935 Answers
SOURCE: what does 5d code on my Kenmore Elite Oasis HE top
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 30, 2010
TheMobilian
  • 8220 Answers
SOURCE: We have a kenmore elite oasis top load washer that
I am seeing a lot of these F-1s so I wrote a tip on it. Click here for the F-1 Information
Posted on Jan 11, 2011
Testimonial: "guick and straight forward. And I actually might be able to do it myself...priceless"
  • 132 Answers
SOURCE: Kenmore Elite Oasis Top Load
Sounds like the main outer tub and bearing assembly is bad. Water has(is) leaking through the main center seal, through the bearings(noise your hearing is these bearings) The tub and bearings with seal and center shaft come as a assembly, not a inexpensive repair. Also the water is getting on a little electronic board called the roto position sensor which can fail, found as part of the motor assembly on the bottom. Causes corrosion on the connection to the wiring. Your main problem is the outer tub assembly........ Good luck.......(I would also suggest you unplug the drain motor(some have a recirculation pump also) to make sure while spinning empty to run only the main motor that this is for sure the noise and water leak if this is your first repair)
Posted on Sep 04, 2011
Oasis HE 27082 Stainless Steel Top Load Washer: how do i soak whites in a kenmore elite oasis?...
There is not a program - you have to do it manually on this machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
How to remove the agitator & the basket on a kenmore elite oasis
See the following Whirlpool Service Manual for their Cabrio washer. It's the same machine as the Kenmore Oasis,
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite #20992 can't remove back housing
Comes apart from the front. 2 screws on front of control psnel; flip it up. 2 clips to pry out; also ulplug lid switch. Cabinet lifts up from back and comes right off. Hope this helps!
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
