Question about Vintage Keeper Koolspace Wine Cellar
AZMN HAL Odyssey - Vintage Keeper Koolspace Wine Cellar
2 Suggested Answers
  • 842 Answers
SOURCE: Cannot get temperature below 65F. Probably
I have never heard of a wine cabinet getting below that range? Has this unit every reach temps that low before? I would make sure the unit is breathing, check the condenser and air flow through the unit. If the unit is not choking, and temps can go below 65, than yes you will need to have it serviced. It can be a thermostat issue.
Good Luck
Posted on Jul 13, 2011
Cannot get temperature below 65F. Probably need replacement cooler unit. Model: AZMN HAL Odyssey Approx Size: 9" H x 15.5" W x 14" D. Serial #: AA4-Odyssey-01201-121
Good Luck
Jul 13, 2011 | Vintage Keeper Koolspace Wine Cellar
Who was Leonard Mozart
The names are seperate... Hal Lenord is a publisher of music books, and Mozart was a composer whose music appears in the book publlished by Hal Lenord company.
Mar 04, 2011 | Hal Leonard Mozart - Selected Variations -...
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Hal.dll
Here is a kink that will give you steps to tak to correct this HAL.DLL issue:
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 16, 2008 | Toshiba Satellite M45-S331 Notebook
Hal.dll error after booting
HAL - Hardware Abstraction Layer (hal.dll)
HAL is Microsoft’s abbreviation for the Hardware Abstraction Layer, the technology and drivers that let the Windows NT, 2000, and XP operating systems communicate with your PC’s hardware. HAL is one of several features–along with the NT file system (NTFS) that replaced the much less secure MS-DOS–that make NT-based operating systems more secure and reliable than Windows 95, 98, and Me.
HAL.dll prevents applications from directly accessing your PC’s system memory, CPU, or hardware devices (such as video and sound cards)–a method that can prevent many device conflicts and crashes. Unfortunately, HAL.dll sometimes also slows or stops DOS games and programs, which need to load their own memory managers or control hardware directly for better performance.
With HAL.dll in the way, developers must rewrite or even abandon their older software in favor of newer, HAL-compatible versions. Microsoft has pressured hardware makers to provide or support technologies such as MMX, DirectX, and 3D graphics language OpenGL, all of which allow fast but indirect access to the advanced high-performance features of video, sound, and CPU hardware. Such access also makes for a better visual experience when using Windows for Web and productivity applications; improved graphics performance is evident all over Windows XP’s new user interface.
XP also offers some new compatibility-mode features that let you run programs meant to run under earlier operating systems, but, frankly, most DOS-based and even some Windows-based games simply won’t work with the new OS.
Oct 05, 2008 | Computers & Internet
Vintage Keeper Koolspace Wine Cellar Logo
388 people viewed this question
Top Vintage Keeper Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
Are you a Vintage Keeper Furniture Expert? Answer questions, earn points and help others
