SOURCE: Kenmore wont agitate or spin
Mindurrs, your motor coupling has gone to the great beyond. Time for mourning has passed and now it must be replaced. The job takes about an hour and parts run about $10.00, ready? First, go to your local appliance parts retailer and purchase a coupling, part #285753. You'll need this for repairs. UNPLUG THE WASHER!!! Standing in front of the washer, you'll see two screws on either side of the control panel... remove these then flip the control panel over. Now, toward the right side, you'll see a wire harness that plugs into the top of the top panel, disconnect this. Now, on either side of the top panel, you'll see two brass colored clips. Take a screwdriver and poke it into the hole, use it as a pry bar. Pry the handle of the screwdriver toward the wall behind the washer, the clip will pop out. Now tilt the entire cabinet of the washer toward you to about a 45 degree angle then lift it out of there and set it aside out of the way for now. OK, now we're into the guts of the washer... Look below and in the center, you'll see the drain pump (it has 2 big hoses attached). Behind that, you'll see the motor... that's what you'll be taking off. On the right side of the motor, you'll see the electrical connections. Remove the long white one from the motor. (CAUTION!!! THIS NEXT STEP MUST BE DONE, OTHERWISE PERSONAL INJURY MAY RESULT!!!) You'll see a black round thing mounted to the motor on the right hand side, this is the capacitor. It has 2 red wires on it. (It's basically a 120 volt battery that is just waiting for you to touch it so it can shock you, badly) THIS MUST BE DISCHARGED (voltage drained off) BEFORE CONTINUING. Remove the 2 wires using insulated needle nose pliers. Now, discharge the cap by touching both terminals of the cap at the same time with your needle nose pliers. This will discharge the capacitor so it's safe to handle. Now, above and below the motor, you'll see 2 clips mounted on it, remove the screws that keep these clips in place then (with a flat head screwdriver) pry the clips off the motor. The motor and pump will drop out of there. Rotate the whole thing off to the left (with the hoses still attached to the pump). Now you can see the broken coupling (compare the old one and the new one). Pry the old pieces off the motor shaft and the transmission shaft and throw 'em away. Install the new coupling (notice the semi-triangular shape of the inside of the plastic coupling? I use my screwdriver handle... poke the handle into the coupling, place the coupling squarely on the shaft, then tap [don't BANG] it home with a hammer) and rebuild in the reverse order of dis-assembly! Sounds complicated, but it's not. I've done a thousand of these and it took me longer to type this than it would have for me to do it for you! And, for what it's worth, you have a good washer there. It's actually made by Whirlpool, and well worth the repair.
SOURCE: ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
SOURCE: Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
SOURCE: Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
