Question about SanDisk Sansa m200 (2 GB) MP3 Player
No response, no turn-on, dead player! help!
I was loading files, when the transfer locked up, and the computer threw an error. i couldn't do anything but unplug the player! After I did this, i tried plugging it back in, and half of the world "initializing" popped up on the screen, the first half was missing! it did not do anything more. so i unplugged it again. Now when I plug it in, nothing happens. The computer recognizes that new hardware is plugged in, but cannot recognize what it is. Nothing comes on the mp3 player's screen. It will not power up when i hit the power button. It has no response, it acts like there is no battery in it. I have taken the battery out, and put it back in. Nothing happens when any of the buttons are pressed, or when it is plugged into the computer. Is there anything I can do to get this thing working again! It is the M260 if that matters.
Same thing just happened to my M260, did you ever get an answer? Thanks, Jeff. Problem: No response, no turn-on, dead player! help!by mtx410 on Aug 28, 2006 I was loading files, when the transfer locked up, and the computer threw an error. i couldn't do anything but unplug the player! After I did this, i tried plugging it back in, and half of the world "initializing" popped up on the screen, the first half was missing! it did not do anything more. so i unplugged it again. Now when I plug it in, nothing happens. The computer recognizes that new hardware is plugged in, but cannot recognize what it is. Nothing comes on the mp3 player's screen. It will not power up when i hit the power button. It has no response, it acts like there is no battery in it. I have taken the battery out, and put it back in. Nothing happens when any of the buttons are pressed, or when it is plugged into the computer. Is there anything I can do to get this thing working again! It is the M260 if that matters.
Posted on Jun 07, 2007
    Problem Solver:
  • 5 Answers
Hi guys! I've got a brand-new solution to this dead-end problem. BUT, the downside is that you'll need another similar player. Here's what I've done to unfreeze my Sansa m230. 1. I've opened the cases of both our Sansa m230s. 2. Connected the healthy one to the computer via USB. 3. After it was connected I've hot-swapped the "Samsung k9k4g08u0m-pcb0" memory chip with the one which was causing the problem. 4. Finally, I've formatted it through WMP10. Only synchronizing in MTP mode using WMP11 since. Hope that helps. Amakorkos
Posted on Sep 25, 2007
I have installed my Vision M on my laptop but when I go to organize music and have the unit plugged into my computer the music organizer does not show the Vision M as a device that can be opened so that...
Hi can you drag and drop files to the player from your my computer where it shows up as a removable device. Not sure why the software does not see it for you to load it but you can drag and drop items to it. Thats how I load my Vision M
If you need any more help, parts or your player repaired you can go to my repair service web page and e-mial me, call me or contact me threw my Ebay user name at from my web page at firehouse7777.weebly.com Thanks
Dec 13, 2010 | Creative Labs ZEN Vision:M Digital Media...
My player got problem
Connect your computer to the sansa, then search for the files using the search key from the start key, search for all files with an * for detecting all the files. Select all and transfer all files to a folder. then delete off all the files and format if the sansa gets detected. if so your memory is back to normal. transfer all your files again back but make sure that the next time you load only the good ones. Hope this helps you off.Good day
Jul 05, 2010 | SanDisk Sansa e250 MP3 Player
My player starts to load, but then doesn't completely turn on or
Try this 1.Push the hold switch towards the headphone jack so you see orange
2.Press and hold record on the left of the player
3.With record still being held down, plug into the computer
4.Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware by copying the firmware files to the detected removable disk.
Firmwares- Version 1 Version 2
Download the correct version or else it will render your device useless.Version can be found on the back plate at botton right.. Extract the downloaded file and transfer the contents to removable disk detected.After transferring,disconnect the player and let it upgrade the firmware
Sep 01, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Syncing with Windows Media Player
Place the music files that you want to transfer into the My Music folder of your computer - Windows will re-read them, and then you can synchronize to your device. Also, make sure the hold/lock switch is not engaged on the mp3 player - it probably isn't, but just check.
-Tha Mp3 Doctor
Dec 25, 2008 | GPX MW-238B MP3 Player
Transferring files back to my PC from my Sony NW-HD5
first off when you transfered them using the sonicstage software it put what are called digital media rights that locked that file to the pc that loaded it, dont worrie there is a way... open up the mp3 player in one window and find the music you want drag it over to your desktop, then get a program called tunebite and that should help
Sep 27, 2008 | Sony Network Walkman NW-HD3 MP3 Player
Yepo digital audio player
hi i can not transfer files to my yepo mp3 it says my comp dosnt support it i have windows vista loaded the manual says i must convert ACT to WAV format could you please tell me how to
thanks
Nov 09, 2007 | Audio Players & Recorders
Transferring music to new pc
You must use the music transfer software that came with the CD (also avail on Rio website) - which will not load on newer, Vista running computers.
May 03, 2007 | Rio Carbon MP3 Player
Help i have a Samsung YP-T9 and it froze
I had a problem with the Mp3, He was hangup while charging the battery from the USB, I disconnected the USB but It still continuated with the screen charging even if this was disconnected, and I couldn`t hear nothing, so I decided to look in the faq of Samsung, It is Ussless like most of the official pages, how to plug, how to listem the music, but nothing nothing information about how to manage my problem,. So I decided to look in google, and the solutioin was here, press the rec button and the menu button at same time, and magicaly the device was unbloqued. Thanks a lot swamped69 for the solution
Mar 19, 2007 | Samsung YP-T8 Digital Media Player
Error message while downloading from the mp3 player
First thing i would do is load the latest firmware and upgrade the dmm manager.
Feb 21, 2006 | Philips HDD120 MP3 Player
SanDisk Sansa m200 (2 GB) MP3 Player Logo
146 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
