Question about Dell 5100cn Laser Printer
How do we add an additional paper tray to the existing printer?
Our original paper tray broke so that we could not "fix" the paper in 8 1/2 x 11 size. I bought a new paper tray and now we need to configure the printer to switch between trays.
  • vlee13009 Nov 21, 2008
    The multipurpose feeder keeps going back to envelopes; it seems to have become the default. How do I change it?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
From the printer menu, go into the paper menu, change the "default source" to tray 2.
Also, on each computer that you have the driver loaded on, you can right click on the printer icon, go to properties, and select your default printing options.
Posted on Oct 30, 2008
Says add paper . I do & still wont print
Select another tray or bypass tray and set it the same size as the damage tray .. Pull out the tray of the damage tray so it will not be detected. When you printout it will select the other tray of the same size.Select the tray from the properties in your computer if not selecting automatically ..
Oct 29, 2014 | Toshiba e-STUDIO166 Printer
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
Printer roller will not engage paper
Make sure you have plenty of paper in the tray, this may help the printer pick it up. if you don't have lots of paper add an A4 sized magazine, book or old printed paper in there, to full the tray.
Is there a way to manually insert the paper from the back, some printers have this feature.
Feb 10, 2014 | Office Equipment & Supplies
Set legal tray
go to in service mode.
Add. function 2,8, additional function.
go to printer
CST
U2 - enter value 36
press ok.
restart machine.
Now put paper CST setting on U2 put legal paper
now. you can get copy of legal
Nov 30, 2013 | Canon iR 2022 Printer
Hp P3015 printer
What you need is the 500-SHEET Laser jet Tray CE530A, It automatically print on two different types of paper such as plain paper and glossy brochure paper without manually loading paper trays for each print job. And Save time and improve the performance of individuals and work teams with the increased paper capacity of this 500-sheet paper tray from HP. With more sheets of available paper, users spend less time refilling paper trays. I hope to hear from you soon.
May 11, 2013 | HP Office Equipment & Supplies
I need additional paper trays, mine only has two.
Yes.
There are 3 Bases that this system will take.
1. Plain Stand (this is the one you have)
2. PB3070 (This will give you an additional 500 sheets and you will
need to add a Caster Base with this option.
3. PB3030 (This will give you 2 addional 500 sheet trays) No Caster
Base needed
Mar 01, 2013 | Gestetner DSc525 All-In-One Laser Printer
My Canon IR1610 is giving wrong paper size message when i used legal size paper(8 1/2 x 13) but it does work on letter size.I did change the value by pressing additional function and set it to LegalR.It...
u have to choose freesize from the bypass tray and then measure ur paper and enter the size in XY.then only u can use it and that too from bypass tray only
Jul 11, 2011 | Canon Office Equipment & Supplies
How do I get the printer to print automatically using the bypass tray
you can set the bypass tray the size you want then set paper size setting in the printer driver at your PC.
Hold down the [PAPER SIZE ENTER] key more than 5 seconds to
set the selected paper size.
The currently selected paper feed location indicator will blink and the
corresponding paper size (which is currently set) indicator will light
steadily.
All other indicators will go out.
If the machine has two paper trays, use the [TRAY SELECT] key to
select the paper tray for which you wish to change the paper size
setting.
Each time the [TRAY SELECT] key is pressed, a paper tray will be
indicated with a blinking paper feed location indicator.
Use the [ORIGINAL SIZE ENTER] key to select the paper size you want to set.
The indicator of the selected paper size lights up.
Press the [START] key and then the [PAPER SIZE ENTER] key.
To change the paper size setting of another tray, repeat steps
after pressing the [START] key
Make sure that the tray's paper size setting is the same as the tray's
paper size setting in the printer driver. For example, if the tray's paper
size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Jul 01, 2011 | Toshiba E-Studio 161 Copier
Adf shows jam when originals placed in adf. adf was checked, no jam found. also trays 1&2 have 8.5x11 paper in them but show A4. how do I change tray size?
to change the paper size for trays 1,2,4 you need to do this in service mode. to get into service mode hit the additional functions button then the 2&8 at the same time then the additional functions button again.
you should be in service mode.
then hit the copier tab...... options tab ..... then the BODY tab in that setting..... and in that menu there should a CST tab in that menu once there you should see tabs for 1 , 2 , 4 you will need to set the value for 1&2 to 18
that should set them back to letter size. email me if you have problems with it
Jun 05, 2010 | Canon imageRUNNER 5000 Copier
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
Dell 5100cn Laser Printer Logo
209 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
