Question about Dell Dimension 8400 PC Desktop
Where can I download Bios in non .EXE form for Dell dimension 8400, motherboard is AA c5134-404?
Dell dimension 8400 3.2Ghz 1024MB ram AA c51354-404 Motherboard Where can I get latest bios software?
  • Dell Master
  • 3,606 Answers
2 Suggested Answers
  • 3940 Answers
SOURCE: Dimension 8400 locks up. Keyboard won't respond.
Generally and indication of a software issue that is locking the system. There can be hardware causes too.
  1. Run diags on the system (From Resource CD or F12 menu) see if any failure. If you have a hardware failure then address it and see if the problem is solved.
  2. Update bios and drivers from support.dell.com
  3. Edit MSCONFIG, startup group, remove entries that are not required (Generally only AV and printer scanner items are needed here, most other items will function without and item here)
  4. Edit the Virtual Memory settings, and set it to Custom and an amount double the RAM (EG: 4 GB RAM set initial and Mas to 8200 MB VRAM)
Posted on Apr 04, 2010
Dell dimension 8400 pc desktop when pressed power botton orange light comes on and system not booting up
Needs attention from a tech. Could be anything at this point, bad ram, bad/dirty ram slot, failing power supply or motherboard, bad video card... I'll put my money on bad motherboard otherwise I hope you would have wrote that you are hearing beeps. Hope that helps you some.
Aug 10, 2014 | Dell Dimension 8400 PC Desktop
When i power my Dell Dimension 8400 it starts up until everything is on my scree. After a minute it just switches off automatically and the power light changes to orange? What seems to be problem?...
First open the cpu cabinet.Then reconnect all connection to motherboard reconnect RAM memory make sure motherboard is not ground with cabinet cover.Then check if still same problem then power supply might be an issue but also this problem occurs because of RAM or motherboard corrupt so check first RAM then power supply then motherboard.Let me know if you need further assistance.Thanks for using FixYa.
Nov 18, 2011 | Dell Dimension 8400 PC Desktop
When trying to boot PC all i get is black screen and message:- X300 SE 128MB BIOS P/N 113-A33406-100. Have replaced bios battery on motherboard an checked connections etc but still displays same message....
no problem friend please open your cpu shutter and you can see here a cell like watch's cell plug it out and replace it with the new one and start your computer now your this problem is 100% solve. thanks
Jul 14, 2011 | Dell Dimension 8400 PC Desktop
My 6 year old Dell Dimension 8400 quit working completely.
Depending on the symptoms, you may have different faults.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Flashing Amber power LED, normally power supply
AAGG Diag LEDs normally bad RAM
Solid Amber Power LED, bad motherboard or Expansion card connected to it.
If you need a motherboard a Precision Workstation 370 motherboard is essentially the same and is available, (8400 motherboards are scarce)
http://shop.ebay.com/i.html?_kw=T7787&_kw=DELL&_kw=Motherboard
Feb 05, 2011 | Dell Dimension 8400 PC Desktop
I messed the bios up on a Dell Dimension 8400 pc. The HD completely died, so I have no OS on the pc, so I can't just simply run the exe bios update from dell. Is there some USB utility that I can use to...
Go here if you can unmount the bios eeprom they will reprogram it for you or send you another of its type with your bios on. I have used this service a few times. Never failed me. GL
http://bios-repair.co.uk/
Jul 28, 2010 | Dell (E210882) Motherboard
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
Apr 04, 2010 | Dell Dimension 8400 PC Desktop
Where should I look in the computer (Dell dimension 8400) for the problem windows shuts down and a blue screen error message saying page fault in a non page area.
Hi friend,
You need to check your ram in your computer.. i think your RAM is not good running...so try to change then ram ...then it will work..
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Dell pc wont boot up
check all power cable, remove the ram and add the ram, remove the agp, remove the bios battery for 5 minutes. then add the ram.
Jan 25, 2009 | Dell Dimension 8400 PC Desktop
Dimension 2400 is at 1.5MG - will not go to 2.0MG per manual!
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
348 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
