TS2000X won't power up
When turning the radio on,the front panel says hello then turns off. The fuses and power supply are ok. Any suggestions?? DE WA9DLS......David
  • 390 Answers
SOURCE: Won't turn on. Power supply OK
Do you get light of any sort? What is the switch set to at the back for voltage if you have this? Post back please lilacgerry xxx
Posted on Feb 11, 2008
  • 286 Answers
SOURCE: viewsonic n3251w - no power
A lot of TVs are having their power boards go bad due to a poor brand of capacitor (CapXon usually).
If small problems are noticed with the tv, the solution is to replace the capacitors. However, once the TV gets to the point where there is no power at all any more (not even a stand-by light) then the power supply has to be replaced.
Visit Viewsonic's website or call your local Viewsonic repair shop to get a price on this board. They are usually under $100.
Posted on Nov 26, 2008
  • 233 Answers
SOURCE: Emachine W2047 No BIOS Start Screen
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Posted on Jan 07, 2009
  • 41 Answers
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Posted on Mar 30, 2009
  • 11 Answers
SOURCE: doesn't turn on
does it have the blue flashing light on the power button?
Posted on May 16, 2010
TV won't turn on
it is maybe power supply is damage,please check the fuse of power supply,if it is fuse is damage,you can change it.if fuse is ok,you can change power supply boards.when you find which boards is defective,you can search by pcb number on www.wisiny.com
Jun 05, 2013 | Craig CLC501 15 in. TV
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Won't turn on
if no any light indicator at the front panel of the monitor, the cause would be power supply failure. to do the check up, you must need to remove the back cover. the power supply board it was connected the power cord. look for a blown fuse and a bulging electrolytic capacitors at the power supply board.replaced those bulged capacitors, you can find at www.digikey.com for parts replacement.
Nov 17, 2012 | ViewSonic VX2255 Monitor
Won't turn on
if no power indicator at the front panel it could be power supply failure, check for blown fuse. if just blinking look for leak or bulging capacitors then replace it.
Sep 27, 2012 | Toshiba 32C110U 32 in. LCD TV
Sanyo DP42647 tv won't turn on.
sanyo LCD tvs recieve the on command from the main board so chances are the main board was also damaged
Jul 06, 2012 | Televison & Video
I have a 1 year old Sanyo Vizon HDTV and was watching a show when it suddenly just shut off and would not go back on again. No storms or any other power surges and it is hooked up to a real surge...
Hello
If there is no power indicator LED lights up when the set is sitched ON, the power regulator section inside your TV is faulty. There is a fuse [glass cartridge type]; on the power regulator board. If this fuse blows OFF the set won't switvh ON of the front power light won't light up. Check this fuse first. You can locate it at its power switching regulator board inside, where the AC power goes straight to it after a filternig circuit. If the fuse is blown out, replace ti with same rating. It ratings will be marked either on its edge rims of on its body by colour code lines. Replace the the fuse; if it has blown out, and switch ON the TV. if the replaced fuse also gets failed, do not put any fuse after, the power supply section has some short with it. It is best to replace the power supply board as a card absis; rather than making "surgery" to it. Some components in it will be very difficult to get too. You can buy a new power board from /Vizio Authorised Service Center at your town. OK.
Jul 14, 2011 | Televison & Video
We have a whirlpool AWM6140/3 1400 spinspeed when I turned machine on it fused the supply at the fuse box not the plug,now it won't turn on
hello because there a dead short somewhere the fuse inside the washer power supply could have blown if this ok you will need to check wiring if ok then there could be a fault with the power supply board hope it helps
regards
shaun
Jan 08, 2011 | Whirlpool AWM6140 Front Load Washer
The radio in our 2008 Aspen is not working at all. The fuse is ok. Is there a way to reset the radio?
Hello, Besides the fuse in the car fuse box, behind the radio you should have another fuse that goes into the power line of the radio "most radio's do" . Tho some don't. That may be what has blown that is keeping it from turning on. I would suggest removing the unit from your dash and check the fuse behind there. Hope that helps ya.
Jan 02, 2011 | 2008 Chrysler Aspen
I have a 50 inch lcd phillips tv. I turned it on this morning and it just keeps clicking . I can't turn it off I had to unplug it.
This Seems to be a Power Supply Boards.Phillips TV's are Popular for their Power Supply problems.
You need to Open the TV. Make sure it would be Unplugged. You need to Take all the Precautions. Locate the Power Supply Board. Remove the Connectors and Pull out the Board. Once you Pull out the Board, with the Help of Magnifying Glass, locate Cold Solder Joint. If Everything is OK, then you would Locate Bulged / Leaked / Swelled Caps. They would have Ammonia kind of Odor. You need to De-Solder them. You could take the same to Radio Shack / Fry's / Order Online. Once you get the New Caps, Solder them and it is all set.You also need to Check Fuses around that.
If the Problem Still Persists, get back to me with Make and Model we would Troubleshoot other Components.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 07, 2010 | Philips Televison & Video
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
