My amcap 1.3 megapixel web cam is not working correctly. it is terribly distorted. what can i do to fix this?
I downloaded the proper software that came with the product. Installed the connections ( usb port wire and microphone wire). It is terribly distorted. I tried to clean the lens and i turned the front knob to try and do it that way but nothing. It wont even let me run it on windows xp, which i have. it gave me options **** as win 2000, win 98, win 95 for example but not windows xp. it says its compatable with win xp on the box. so what can I do?
otacon
  • 1944 Answers
SOURCE: Appears to be installed properly but doesn't record
When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
    For Windows:
  1. On the bottom left of your screen, select the "Start" menu.
  2. Select "Settings" then "Control Panel".
  3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
  4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
  5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
  6. Under "Sound Recording," select "USB Audio Codec" for your default device.
  7. Check the box titled "Use only default devices".
  8. Click "Apply"...then "OK".
    For Mac:
  1. Open your Hard Disk.
  2. Open your "Applications" folder.
  3. In the "Applications" folder, open the "Utilities" folder.
  4. In the "Utilities" folder, open the "Audio MIDI Setup".
  5. In the "Audio MIDI Setup" under Audio Devices, set:
    • "Default Input" to "USB Audio Codec"
    • "Default Output" to "Built In Audio"
    • "System Output" to "Built in Audio"
Now, all programs, including Audacity, will only use your internal sound card for audio output.
Posted on Dec 26, 2007
SOURCE: Samson C03 Microphone using with Realtek HD Audio Manager
SEU MICROFONE PRECISA DE UM RECURSO CHAMADO PHANTON POWER QUE NADA MAIS é DO QUE UMA ALIMENTAçãO DE 48 VOLTS, PORTANTO NECESSITA DE UM APARELHO INTERMEDIARIO, COMO UMA MESA DE SOM COM ESTE DISPOSITIVO OU UM ADAPTADOR PHANTON POWER COM SAIDA USB PARA O SEU PC, NO CASO DA MESA TAMBEM é NECESSARIO UMA PLACA DE AUDIO COM CONEXãO USB EXEMPLO UCA 202 DA BEHRINGER , PODES CRER Só ASSIM FUNCIONA E SOM é MUITO BOM.
Posted on Aug 06, 2008
SOURCE: My Samsung Tocco wont connect to my laptop with the software on
I think u would not had installed the drivers software properly. Uninstall the drivers for ur phone in ur laptop . then without connecting the phone to the laptop install the drivers . now restart and connect the phone to ur laptop . go to add hardware option and add the phone. now it'll ask for the location of software. select the option as cd. it'll ask for the port no. and all other details.. give them correctly ... select ur phone from the list and install it. now ur phone is ready to work with ur lap top
Posted on Mar 08, 2009
siawolf
  • 749 Answers
SOURCE: Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Posted on Apr 01, 2009
  • 5 Answers
SOURCE: Windows XP Pro USB HID problem.
First suggestion is to shut down, change ports and then, upon reboot, wait a few minutes to let XP resolve the 'new' USB devices.
Second suggestion is to download and install the manufacturers drivers and then try switching ports.
Final suggestion is to use the port that works. i.e. I went to the doctor and said "It hurts when I do this". He replied "Well, then don't do that.".
Good luck
p.s. you may want to list the model of the keyboard if you would like a more specific response.
Posted on Sep 09, 2009
Built in mic by web cam does not work
i think your mic is working properly. so you can download the camera software (amcap is better) from anywhere.
if you need more help just use the link http://amcap.en.softonic.com/download
Mar 28, 2011 | HP G70-250us Notebook
My cam works with msn but that's it i can't take pictures or make videos or use the backgrounds etc
Copy this site and paste it in your browser ADDRESS
Bar and hit ENTER;
http://www.free-codecs.com/AMCap_download.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20
AMCap is a small yet fully functional video capture application compatible with Microsoft
DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports
still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard
and Video size settings from previous session. It has some nice features like multi-monitoring support, zooming, aspect ratio and interlacing features.
program.
AMCap is a small and effective piece of software and definitely worth trying.
Hope this will help. Bud
Mar 21, 2010 | Microsoft LifeCam Show Webcam - 2.0...
My built in web cam on my laptop wont work
Normal 0 Double Click on this site
AMCap v9.20 AMCap is a small yet fully functional video capture application compatible with Microsoft DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard and Video size settings from previous session. It has some nice features like multimonitoring support, zooming, aspect ratio and deinterlacing features.
AMCap is a small and effictive piece of software and definitely worth trying. Hope this will help. Bud
Mar 27, 2009 | Umax AstraPix PC100 Webcam
No video capture device was found on your system
http://www.free-codecs.com/download/AMCap.htm
Feb 12, 2009 | Genius VideoCAM Messenger Webcam
Photos
Jan 17, 2009 | Logitech QuickCam Pro 9000 Web Cam
Problem with instalation web camera eye 110
www.camera-drivers.com
driver should be there if that does'nt help let me know and please rate me
have you tried open software cd to view the files and then download the amcap exe right from there
Dec 23, 2008 | Genius VideoCAM Eye Web Camera
DirectShow amcap sample fail to run my HP web cam.
Sep 14, 2008 | HP EW192AA Webcam
Web cam not able to see when it is on and system says it is working properly
Aug 24, 2008 | Philips SPC 200NC Webcam
Unable to capture web cam photos
Mar 05, 2008 | Computers & Internet
Sting ray web cam
Nov 29, 2007 | Veo Connect Webcam
Computers & Internet Logo
David Payne
David Payne
