Question about Toys
Traxxas ez start does not light glow plugs - Toys
5 Suggested Answers
  • 88 Answers
SOURCE: starting problem
Could be a bad glow plug. I would start there, they are inexpensive and easy to change.
Posted on Dec 11, 2009
SOURCE: wont start have a traxxas revo 3.3
Hello!! ,
To the point!!! , All gas cars are "Nitro" , there are "Gas" Cars but there more expensive and fairly new... , by my experience Ez starters dont have wires on them in order to start the motor.. , if you cut!! a wire.. in there maybe it could be it... , but these cars dont need ground wire.... ,Sooo if u say its ground wire i dont think theres a problem , its only incase if there's an electrical over-out-charge that will put the chips in danger... , so THIS MESSAGE IS QUITE COMPLICATED : ) ... ,
and it shouldn't turn over there not designed that way , only if you put another motor that maybe is'nt apropriate that has more speed or power if i may or it does'nt have a back "Wheel" Slider..., and if the gears got something in it well... , maybe they might chiped a "Tooth" there and is not gearing well wich may lead to more gear problems as u can imagine , check the steering batteries too , or maybe it just needs "Idle-ing" so the motor can run Fine and Dandy like Tom Hanks says jaja , but i think the problem is that your not Idle-ing it well in twisting the Knob fairly 1/8 at a time to get a smooth sense and sound of the motor because it can over heat , or maybe there's something about the carburator that's not working well , Orrrr maybe it needs a clean with white Gas in unscrewing all the "Motors" Parts and cleaning them for a while so the motor can run better , Ive got an Exceed Rc "Mad Storm" so im kinda of guessing but they all work quite almost the same , Hope this helps : ) Ciao!!!!!
Posted on Apr 13, 2010
SOURCE: hi my name is fabio i have got a traxxas nitro
So you never had it running yet? Or did you ? Can you turn the motor by turning the flywheel ? If not it is seized and you need to heat up the motor to turn the engine again. Leave it at BDC ( bottom dead center) when you turn it off.
Posted on Mar 12, 2011
SOURCE: How to take the glow plug wire from the part were
when you get a new glow plug wire a tool is packaged with it and instructions its a small brass tube you slip over the pin to release it.
Posted on Aug 23, 2011
My New T-Maxx 3.3 wont start
Maibe the starter wassent charged all the way this happend with mine
Mar 22, 2013 | Traxxas T Maxx 3.3 Monster Truck
Traxxas Monster truck won't start
i always gave mine half throttle for 2 pulls, attatched the glow plug batt, and bam, started right off next pull
Feb 25, 2013 | Traxxas T Maxx 3.3 Monster Truck
How to take the glow plug wire from the part were there ez start goes
Aug 06, 2011 | Traxxas Rc Revo Nitro Monster Truck
Revo 3.3...engine doesnt stay on...
Could be a couple of things. Firstly the glow plug may need changing or youre running slightly rich. If you was replacing the glow plug you should retune the engine anyway. When the fuel is entering in the engine where the glow plug is theres either to much fuel and flooding plug out or the plug is not up to the job of burning the fuel. Replace plug and retune. You have had car for two years so guessing you know how to tune the engine.
May 27, 2010 | Traxxas Rc Revo Nitro Monster Truck
My revo is getting fuel light on start remote are on both motor and glow plug engine will just turn over but will not start up
Hi
You've checked the glow plug externally to see the wire get red? If so, as long as you've got fuel and fire then it has to start. My guess here is that you have either a bad glow plug, low batteries, fuel air leak or clogged pressure line. Put a charged battery into the starter. Remove the glow plug and try to start - fuel should spurt up through the glow plug opening. Now connect the glow plug and touch it to the engine. Try to start and you should see the glow plug wire glow red. (do this only for a second. Now disconnect the pressure tap from the muffler and try to start. All else fails, replace the fuel line to the carb and the pressure tap. Your carburetor can leak air through the rubber gasket . Also, Traxxas fuel tanks have a cracking problem. Good luck
Apr 14, 2010 | Traxxas Rc Revo Nitro Monster Truck
I have a t maxx 2.5 and i had took the electric starter off and put a recoil sterter on and now how are my supposed to heat the glow plug
you can buy a glow plug igniter or do what i did and cut the engine off of your EZ-Start and just use it to heat the glow plug... it's easy to put the electric engine back on. so either way will work.
Mar 02, 2010 | Traxxas T Maxx 3.3 Monster Truck
Having problems with starting my tmaxx the ez start motor wont turn the motor over it seems like it does not have enough torque i have broke the motor in already started fine yesterday and wont start today
you might have your engine hydro locked. easy solution to this. empty your gas tank, take your glow plug out, turn your truck up-side-down and crank it over a few times. put everything back and you should be ready to play again. what happened is you probably flooded your engine. another possibility is your battery for your EZ-Start isn't charged enough, so before you go through the hassle of the above steps, check your battery first.
Jan 13, 2010 | Traxxas T Maxx 3.3 Monster Truck
I have a traxxas revo 3.3 and it turns over but it will not start what do i do
The glow plug could be bad. If the motor turns over and is getting fuel I would replace the glow plug.
Jan 07, 2010 | Traxxas Rc Revo Nitro Monster Truck
The thing you put on the back of the truck will not work only the motor lite comes on but i no its not the glow plug
Have you charged the battery in the EZ Start wand? If you have is the motor turning over at all? If the motor is turning over but not firing it could be the glow plug. If the motor trying to turn over but won't, the engine might be flooded. If it is flooded remove the glow plug and turn the truck upside down. Fuel will run out of the engine. If fuel runs out of the engine, put the truck back down on its wheels. Cover the engine head with a rag and turn the engine over with the EZ Start wand with the glow plug still out. This will remove all excess fuel from the engine. Reinstall glow plug and try to start again.
Oct 21, 2009 | Traxxas Rc Nitro Stampede Rtr 2wd Monster...
Starting problem
Feb 09, 2009 | Traxxas T Maxx 3.3 Monster Truck
Toys Logo
208 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
